Noisy Gear drive for a 472?
Results 1 to 10 of 10
500, 472, 425, 368 Discussion, Noisy Gear drive for a 472? in Cadillac Engine Discussion; Does anyone know if they make a Noisy Gear drive for the 472?...
    68deville&99escalade is offline Cadillac Owners Member
    Jul 2004
    17
    lux hauler is offline Cadillac Owners Connoisseur
    Jan 2003
    Ohio
    47
    1,258
    Re: Noisy Gear drive for a 472?
    nope.....nothing like that made.
    Ogier is offline Cadillac Owners Member
    49
    19
    You might check Pete Jackson...
    Good luck
    Ogier
    JTraik is offline Cadillac Owners Enthusiast
    Automobile(s): Too many...
    Mar 2004
    849
    What is this... Noisy Gear Drive?
    Jul 2004
    17
    you basically get rid of your timing chain, and instead it is run by 2 smaller gears in between the crank & cam pulley under yout timing cover. But the noisy one, also gives a loud wining sound, almost like a supercharger. Alot of Hot rod people use em in chevys.
    I really want one for the car, if anyone finds out, please post it.
    Jan 2003
    Ohio
    47
    1,258
    Let me try this again......
    There are, at this time , no gear drives available for the 472/500 engines.
    The people that are getting performance parts made for these engines are people looking to make lots of power. Gear drives don't make power......they rob power. Cloyes make an excellent roller timing set-up though.
    wurstarme is offline Cadillac Owners Member
    Apr 2004
    22
    Quote Originally Posted by lux hauler
    They rob power? How substantial is the reduction?
    Jan 2003
    Ohio
    47
    1,258
    How much I'm not sure.
    As I understand it....the reason they make noise is because of the way the gears mesh together. There is more resistance with the gear set up than there is with a chain.
    I'll do a little research and see what I can come up with.
    49
    19
    ExclamationRe: Noisy Gear drive for a 472?
    In my experience, anything more than about 450hp and gear drives tend to start coming apart.
    This is why I refuse to use one under any circumstances. Not worth the risk.
    Ogier
    TorqueInc's Avatar
    TorqueInc is offline Cadillac Owners Member
    Jul 2004
    90
    Gear drives transfer harmonics from the crank to the cam and on a small broomstick of a camshaft like the cadillac it is a very bad idea
    buy a cloyes and enjoys its troublefree nature
  13. Remove Advertisements
