Results 1 to 3 of 3
Thread: thermostat replacement
    Jul 2004
    1
    What do you have to do to replace thermostat on 500ci 76 sedan deville?
    move air conditioning compressor or is there some easier way?
    help!!!
    May 2004
    tx
    90
    Re: thermostat replacement
    Try a distributor wrench, usually works. Worst case, loosen belts and remove compressor mounting bolts and move compressor just a little to get access. No need to disconnect anything to compressor.
    Jan 2003
    South of a Cornfield, IA
    1,380
    what he said either use a wobble on a socket or mave the compressor off to the side. its easier than it sounds
  • You may not post replies
