Rearend question
Results 1 to 5 of 5
500, 472, 425, 368 Discussion, Rearend question in Cadillac Engine Discussion; Does anyone know what a '74 Coupe DeVille with a 472 would have for a rearend stock? I'm just curious ...
    wurstarme is offline Cadillac Owners Member
    Apr 2004
    22
    Rearend question
    Does anyone know what a '74 Coupe DeVille with a 472 would have for a rearend stock? I'm just curious about mine, and I'd rather not have to jack the car up to find out.
    Angela Desmond is offline Cadillac Owners Fanatic
    Apr 2003
    new windsor new york
    60
    193
    Re: Rearend question
    Definitely a 10 bolt, I'm pretty sure it's an 8 1/2 " ring gear, and posi was an option.Numbers are stamped onto the right hand side of the axle tube about 3" out from the differential. Haynes manual doesn't have the codes for those numbers but Chiltons should. It tells the year of manufacture and the gear ratio. By '74 highway gears were in vogue, so figure on somewhere around 2.70:1. That's a guess, but it should be close.hope that helps.
    Apr 2004
    22
    Thanks for the info, much appreciated
    Keith is offline Cadillac Owners Member
    May 2003
    12
    My '75 SDV came with a 3.41 gears
    Apr 2003
    60
    193
    I can only gasp at what your gas milage must have been with those gears!
  8. Remove Advertisements
