Replacing air cleaner assembly, K&N?? HELP
Results 1 to 2 of 2
500, 472, 425, 368 Discussion, Replacing air cleaner assembly, K&N?? HELP in Cadillac Engine Discussion; I want to replace my air cleaner assembly to a K&N 14" diameter x 3" on a 1971 Caddy Coupe ...
    mclife is offline Cadillac Owners Member
    May 2004
    7
    I want to replace my air cleaner assembly to a K&N 14" diameter x 3" on a 1971 Caddy Coupe Deville 472. I found these, (links below each one), but don't know which one will fit best. Any help??
    --Matt
    Air Cleaner, Chrome, 14 in. Diameter x 3 in. Filter Height, 2 3/4 in. Total Height, 1.25 in. Drop Base
    http://store.summitracing.com/partde...-60-1280&N=120 4294925239 4294924498 300852
    Air Cleaner, Chrome, 14 in. Diameter x 3 in. Filter Height, 4 5/8 in. Total Height, 9/16 in. Above Carb Flange
    http://store.summitracing.com/partde...-60-1264&N=120 4294925239 4294924498 300852
    Angela Desmond is offline Cadillac Owners Fanatic
    Apr 2003
    new windsor new york
    60
    193
    Re: Replacing air cleaner assembly, K&N?? HELP
    If your wondering about hood clearance, I would try to mock up the stock air cleaner to be the same height as the aftermarket options and put 1 or 2" pieces of clay on top of the cleaner to see how much they squash when you close the hood, of course closing it gently on the first try.
