'76 Eldorado compression test
Results 1 to 3 of 3
500, 472, 425, 368 Discussion, '76 Eldorado compression test in Cadillac Engine Discussion; considering buying a '76 Eldorado. I want to have a manual compression performed on each cylinder. However, I don't know ...
    jace is offline Cadillac Owners Member
    Jul 2004
    25
    considering buying a '76 Eldorado. I want to have a manual compression performed on each cylinder. However, I don't know what the standard compression psi is for the 500cu in. (8.5:1 compression ratio) engine. Is the standard amount of psi 140-160psi?
    crazyliver is offline Cadillac Owners Member
    Mar 2004
    3
    Re: '76 Eldorado compression test
    I can't answer your question directly, but when you are checking any motor for compression, look for consistency. They should all be within 10% of each other, any more than that variance there is likely a problem.
    Angela Desmond is offline Cadillac Owners Fanatic
    Apr 2003
    new windsor new york
    60
    193
    120PSI should about do it for your motors top compression readings.Above 90 and it should still be sound. Below that and I'd start to wonder...
