Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > 500, 472, 425, 368
500, 472, 425, 368 This forum is to discuss the old big block Cadillac engines.
Cadillac Forums: will fit a 500 in a '67 eldorado
Old 11-09-08, 02:40 PM
Cadillac(s): Cadillac Eldorado fleetwood sportscoupe 1967
View '67 eldorado's Photo Album
Casino Cash: $395
Hello,
I have a '67 eldorado
and the engine is gone up in smoke
Now i have the plan to put a 500 engine in this beauty
Can anyone tell me what mods i have to do to make it fit?
Grtz
GP
  #2 (permalink)
Old 11-21-08, 06:28 PM
Casino Cash: $395
Re: will fit a 500 in a '67 eldorado
Anyone?
  #3 (permalink)
Old 11-21-08, 08:33 PM
Cadillac(s): Cadillac 78 Seville, 78 Coupe de Ville, 92 Sedan de Ville
View cadillac_al's Photo Album
Casino Cash: $10085
I'm stumped and I'm surprised nobody else jumped in. I think this question has come up before and I think it was doable. Maybe the bump will get you some help.
  #4 (permalink)
Old 06-15-09, 10:32 PM
Cadillac(s): Eldorado
View BRUCE ROE's Photo Album
Casino Cash: $3485
Your 1967 THM425 trans won't bolt up to a 472; 2 of the bolts are positioned wrong. However you could drill 2 new holes in the trans, or get a '68 up trans, or rebuild your 67 switch pitch trans internals into a newer case.
If your 472 isn't from an Eldorado, you'll need Eldo oil pan, maybe oil pump,
and exhaust manifolds. The 472 is a new design, expect details different.
Accessories, you might need to use a 472/500 set, or at least brackets. Not sure about engine mounts, but they are similar.
Bruce Roe CLC advisor, # 14630
  #5 (permalink)
Old 06-25-09, 12:37 PM
CadVetteStang's Avatar
Cadillac(s): 70 Eldorado w/500, 82 Eldorado w/472, 72 Mustang w/Cad 500
View CadVetteStang's Photo Album
Casino Cash: $1070
It is a doable swap. Someone from my Caddy performance group did it. I’m not sure what mods are needed, but from the above reply, I would think that pulling the whole engine/tranny unit from a 70 up Eldo. I’m not sure if the 71-76 spindles are the same as 69 - 70, but while the engine is out, it would be a good time to do a disc break upgrade since the steel lines would need to be changed too. If you can find a 69 or 70 in salvage, then you can get everything you need and it should be a direct bolt on. They guy who did the swap said he also wants to eventually install a blower.
Note: The exhaust outlets on the heads come out in the same location as the 460 Ford does (the engines were designed by the same man) so it is possible that 460 Ford headers could be found that would work in that body with modifications. The exhaust flange would have to be changed to get them to bolt to the Caddy block – but Caddy 500 performance shops sell those flanges as well as header gaskets. They may also know if anyone has found headers that will fit that body; when I get my 70 Eldo back on the road, I will be looking for headers – but they may have to be custom built for it.
~Good look with the car, and don’t let me talk you into too many upgrades at one time- it is better to finish it one mod at a time and drive it than to tackle too many projects at one and wind up with a basket-case that sits in the garage for two years.
  #6 (permalink)
Old 06-26-09, 01:54 AM
Casino Cash: $3485
Getting a 68-78 complete drive train will supply all the parts you need. The trans will no longer be switch pitch. The later final drive will be A 3.07 or 2.73 ratio, instead of the early 3.21:1.
Headers are a real problem on these cars, because the trans gets in the way on the drivers' side. Bruce Roe
  #7 (permalink)
Old 07-03-09, 10:51 AM
70eldo's Avatar
Blues Almighty
Cadillac(s): 2006 CTS Sport Luxury; 1970 Eldorado
View 70eldo's Photo Album
Casino Cash: $3804
Originally Posted by '67 eldorado View Post
Hello,
Grtz
GP
Hey buddy!
I can hook you up with some people who can help you in Holland. Send me a PM.
  #8 (permalink)
Old 10-19-09, 02:09 PM
Casino Cash: $395
Smile Re: will fit a 500 in a '67 eldorado
Well i'm in the middle of the engine swap
I got the motor and tranny from a '72 eldorado.
The good news is...it's in the car
  #9 (permalink)
Old 10-19-09, 02:27 PM
Casino Cash: $395
the bad news is the oilfilter (ac delco) is not free from a steering bracket
It's a complete swap from the '72 eldo
including brackets and motormounts.
Do i need other motor brackets or will i have to cut of a piece from the steering bracket?
Has anyone delt with this problem?
Hope you guys can help me
grtz
'67 eldorado
from holland
  #10 (permalink)
Old 10-19-09, 02:54 PM
Casino Cash: $3485
There are several oil filter mounts for 68-78 engines, that move the exact position of the oil filter. However, I'm surprised the 72 Eldo engine setup has a problem. Getting a different filter mount might fix it if you have access to some. Or an oil filter relocating kit could be a fast fix. If it was just an interfering bracket, I would look at modifying it, but not any moving parts. Some later oil filters are smaller, would that help? Is the car right hand drive? Might need a picture here to understand exactly the problem. Bruce Roe CLC # 14630
  #11 (permalink)
Old 10-19-09, 03:54 PM
Casino Cash: $395
'the car is a left hand drive ('72 also)
A smaller filter would help
I'll try to make some pictures this week of the problem en post it here
thnx for the quick response
grtz
'67 eldorado
  #12 (permalink)
Old 10-19-09, 07:48 PM
Casino Cash: $3485
If you don't have a place to post the picture, send me a copy at bcroe@juno.com Bruce Roe
  #13 (permalink)
Old 10-19-09, 10:35 PM
Cadillac(s): '85 FWD fleetwood, '93 fleetwood Bro
View steelybill's Photo Album
Casino Cash: $2270
There are oil pumps available that tilt the filter can down, which may help. The Cad Co. has them, and I have one on a 500 that's going in a Chevy.
  #14 (permalink)
Old 10-21-09, 05:10 PM
70eldo's Avatar
Blues Almighty
Casino Cash: $3804
'67 Eldorado,
check out http://www.katella.nl/
He works on Eldorado's and is a member of the Cadillac Club Nederland. He will be able to help you out with parts as well.
  #15 (permalink)
Old 10-22-09, 04:22 PM
Casino Cash: $395
I've posted some pictures of the situation in my photo album
so you guy's can have a look of what's my "problem"
Tags: ,
500, eldorado, fit
