  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > 500, 472, 425, 368
500, 472, 425, 368 This forum is to discuss the old big block Cadillac engines.
Cadillac Forums: 472 fuel pump with or without push rod
Old 11-03-08, 10:35 PM
Cadillac(s): Cadillac
View Coogan 1031's Photo Album
Casino Cash: $820
hello,
i plan on having a fuel pump changed on my 73 deville. does anyone know if the fuel pump for a 472 has to be connected to a pushrod that sits under the cam or does the fuel pumps arm just sit under the cam with no push rod? can you literally take it out of the box and install it or do you recommend any lubrication to the pump and arm? any tips on the install will be really appreciated!!
THANK YOU!!
  #2 (permalink)
Old 11-04-08, 09:16 AM
View jk1000's Photo Album
Casino Cash: $300
Re: 472 fuel pump with or without push rod
The fuel pump is driven by a camshaft eccentric. So, in other words, the fuel pump arm rides directly on the eccentric. The eccentric pushes the arm downward. To aid installation, you may wish to crank the engine until the eccentric is at its low point (which is actually the upward most position). Use a light and mirror if necessary, and look through opening where the pump mounts.
Pre-Lubrication of the arm should not be necessary as it will quickly get oil run-off from the timing chain and camshaft sprocket.
Good luck !!!
  #3 (permalink)
Old 11-04-08, 09:47 PM
Casino Cash: $820
many thanx to everyone who gave me great advice for my 73 caddy. the new fuel pump was installed today and let me tell ya WHAT A DIFFERENCE!! it idles better and runs out like that big block caddy should! once again thanx alot!
Coogan 1031
472, fuel, pump, push, rod
attach your bluetooth cell phone to onstar
flash wax for your cadillac
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum
