Oil pressure in TH425 transmission?
Results 1 to 3 of 3
500, 472, 425, 368 Discussion, Oil pressure in TH425 transmission? in Cadillac Engine Discussion; I must change rusted oil cooler lines (from tranny to cooler), so does anyone knows, what material i must buy ...
    vanaisa's Avatar
    vanaisa is offline Cadillac Owners Enthusiast
    Automobile(s): `65 DeVille Convertible´67 Eldorado,´02 DHS
    Apr 2003
    Tallinn, Estonia
    48
    517
    QuestionOil pressure in TH425 transmission?
    I must change rusted oil cooler lines (from tranny to cooler), so does anyone knows, what material i must buy (copper isnt good solution, i think). I find steel lines (plated with copper inside and outside). They hold pressure up to 180bar - is it enough?
    lux hauler is offline Cadillac Owners Connoisseur
    Jan 2003
    Ohio
    47
    1,258
    Re: Oil pressure in TH425 transmission?
    Steel lines should be good enough. I'm not sure about the copper coated lines though....? What would be the reason for using that?
    vanaisa's Avatar
    Apr 2003
    Tallinn, Estonia
    48
    517
    Thanks, lux hauler - they are some sort of brake lines. I didnt find here plain steel lines.
