Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > 500, 472, 425, 368
500, 472, 425, 368 This forum is to discuss the old big block Cadillac engines.
Cadillac Forums: 77 fleetwood brougham engine
Old 10-16-08, 10:58 PM
Cadillac(s): Cadillac
View george405's Photo Album
Casino Cash: $355
Hi all, I have a 77 caddy with 425 engine, it smokes sometimes when press on accelerator, then goes away, white smoke. Does any one know where I can get a shortblock 425? reasonable? any ideas on the smoke also welcome. I will consider a wrecked car with good motor also, thanks george.
  #2 (permalink)
Old 10-17-08, 10:14 PM
Cadillac(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
View deVille33's Photo Album
Casino Cash: $4375
Re: 77 fleetwood brougham engine
It sounds like one of your head gaskets is giving up. There is propably enough sealing left at normal operations, but under hard acceleration it draws coolant across the seal. It could also be that your radiator cap isn't holding pressure and overfilling the reservoir, which dumps on the same side as your exhaust system. The easy check is to install a new 16# cap and try again. If you are sure it's coming out the tailpipe after that you better hurry to your mechanic and have a block check test done.
brougham, engine, fleetwood
