RESTORE - ENGINE RESTORER on Cadillac V8?
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
500, 472, 425, 368 Discussion, RESTORE - ENGINE RESTORER on Cadillac V8? in Cadillac Engine Discussion; I have a 1967 deville with 429ci V8. I am wondering if anyone have used Restore - engine restorer and ...
    wojtekj is offline Cadillac Owners Member
    May 2004
    17
    I have a 1967 deville with 429ci V8. I am wondering if anyone have used Restore - engine restorer and lubricant on their cadillacs? If so, did it make any difference in mileage or power?
    Thanks
    Imprl59 is offline Cadillac Owners Fanatic
    Jan 2004
    300
    Re: RESTORE - ENGINE RESTORER on Cadillac V8?
    If you have a problem with excessive blowby the Restore stuff will make it smoke less for about a hundred miles. Thats the only benefit I have ever seen from it. Some of the less scurpulous car lots use that kind of stuff to pass off a bad car.
    Steve B.
    illumina's Avatar
    illumina is offline Cadillac Owners Connoisseur
    Automobile(s): '98 Buick Regal LS - '91 Caddy Seville - '87 Caddy Seville!
    Feb 2004
    The Empire...
    4,425
    Quote Originally Posted by wojtekj
    Thanks
    all boils down to this question...do you beleive in flying carpets? :coolgleam
    cadillacdeville's Avatar
    cadillacdeville is offline Cadillac Owners Fanatic
    May 2004
    Longview Tx
    31
    250
    Yes, I have used it on my 77 sedan deville with a 425 and a 143,000 miles on it and it does wonders for compression decreased the oil usage of the engine plus I put it in every oil change with havoline high mileage oil works real good I would definitely recommend it.
    illumina's Avatar
    Feb 2004
    The Empire...
    4,425
    Quote Originally Posted by cadillacdeville
    it may work to a degree...but if your motor is smoking like uncle buck's car, then you may need more than hida-smoke in a can. i would however suggest lucas oil stabilizer, that would be much better than the other stuff out there.
    May 2004
    Longview Tx
    31
    250
    hey I've seen that lucas stuff is it any good
    illumina's Avatar
    Feb 2004
    The Empire...
    4,425
    good for an engine that is high miles, that does not smoke in exess...it is like a synthetic additive, that is supposed to help keep compression managable and add life to the existing oil in the engine. by no means a cure for a bad motor though.
    Tickle Me Eldo is offline Cadillac Owners Member
    10
    Quote Originally Posted by illumina
    Night Wolf's Avatar
    Night Wolf is offline Cadillac Owners 10000+ Posts
    Automobile(s): Unicycle
    Mar 2003
    Where I park it
    11,009
    the restore stuff just thickens up the oil.... I honestly woudln't try it....
    ... I ran a bottle of Lucas oil stablizer (I like Lucas products alot) in my Oldsmobile over the winter.... I really didn't notice anything.. I ran 10W-13 in it at the time, but I then switched to 5W-10 for better flow (plus it is what the cap says) although that engine dosn't smoke or burn oil or anything....
    if the enigne smokes alot... it needs a ring job... if you want to get the longest life from it... use :::: synthetic.... Mobil 1 or AMSoil is the best...
    JohnnyO's Avatar
    JohnnyO is offline Cadillac Owners Fanatic
    Automobile(s): '99 Eldorado, '04 DeVille
    Nov 2003
    Pittsburgh, PA
    194
    CoolRe: RESTORE - ENGINE RESTORER on Cadillac V8?
    :coolgleam I saw photos of a test at www.bobistheoilguy.com of Lucas, at least what showed up there was that it caused the oil to foam up.
    illumina's Avatar
    Feb 2004
    The Empire...
    4,425
    Quote Originally Posted by JohnnyO
    man, that sort of freaks me out!!! but i have been using lucas for a couple of years too. hmm...maybe i should check into using it a little more, huh?
    Night Wolf's Avatar
    Mar 2003
    Where I park it
    11,009
    the funny part is... on the side of the 4, 6 and 8cyl restore cans, they have a little graph and shows how it brought the compression up....well, on the 8cyl one it says 1978 (I think) Cadillac 8cyl.... must be the 425 then.... and has a graph with before the compression is like 30-40 for each cyl and after it is 60-70... just funny how they did the "test" on a Cad....
    May 2004
    Longview Tx
    31
    250
    I use it every time I change my oil and when I replaced the valve cover gaskets there was no burnt or crusted oil on the rockers or any place on the cylinder head and no sludge or crusted crap in the oil pan when I replace the gasket there plus at a 150,000 mile my 425 consume 0 oil. so if you've never tried it don't knock it.
  16. #14
    Ogier is offline Cadillac Owners Member
    49
    19
    ExclamationRe: RESTORE - ENGINE RESTORER on Cadillac V8?
    The stuff is garbage. If you don't want sludge in your engine, don't run cheap motor oil, anything from penzoil or quakerstate.
    Also, don't change brands of motor oil. Different refineries use different chemicals and when they combine, sludge happens.
    Personally, on older engines, I absolutely refuse to use a multi-viscosity motor oil. If you wish, I will post why, but it is far too detailed for this thread.
    Ogier
  17. #15
    TheCanadianWannabe is offline Cadillac Owners Member
    Mar 2004
    Winnipeg, Manitoba, Canada
    36
    17
    Re: Uncle Bucks Car
    ...but if your motor is smoking like uncle buck's car...
    How did they get Uncle Buck's car to smoke like that? Did they fill it with diesel? How can I get my car to do that? Seriously!?! :drinker
  18. Remove Advertisements
