Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > 500, 472, 425, 368
500, 472, 425, 368 This forum is to discuss the old big block Cadillac engines.
Cadillac Forums: Help. EFI 76 eldo won't start
  #16 (permalink)
Old 09-29-08, 02:59 AM
Cadillac(s): 94 ETC,97 STS
View zonie77's Photo Album
Casino Cash: $7854
Re: Help. EFI 76 eldo won't start
Harbor Freight for a cheap gauge...or you can make one from an R12 gauge set, but I wouldn't use it for AC again.
  #17 (permalink)
Old 10-22-08, 09:08 PM
Cadillac(s): Cadillac
View twoten1957's Photo Album
Casino Cash: $665
Finally got around to Harbor Freight and bought the fuel injection tester. Worked like a charm. I have 40 psi at the fuel rail so I guess both pumps are working. I was hoping that a pump was bad so I could replace and get back on the road. Guess back to teh drawing board. Any tips let me know. Thanks
  #18 (permalink)
Old 10-24-08, 12:31 AM
Cadillac(s): 95 fleetwood 81 deville
View drmenard's Photo Album
Casino Cash: $4382
Okay now you want to find out if its spark or a gas problem...Take of the air cleaner and spray starting fluid in and see if it fires up for a few seconds...if it does than you got a computer problem ..if it does not fire up you have a spark problem.. could be the module or coil... if it is the computer it could be a sensor or switch... let us now what you find...
  #19 (permalink)
Old 10-24-08, 12:46 PM
Casino Cash: $665
Must be a gas problem. Shot some fuel in the throttle body and it fired right up then died. I till have to buy that noid tester i guess and see if the injectors are shooting fuel. I need to check my ecm connections too.
  #20 (permalink)
Old 10-26-08, 05:44 AM
Cadillac(s): Cadillac 78 Seville, 78 Coupe de Ville, 92 Sedan de Ville
View cadillac_al's Photo Album
Casino Cash: $10185
Is it holding 40 psi while it is cranking?
  #21 (permalink)
Old 10-26-08, 08:30 PM
Casino Cash: $665
It looks like the gauge drops when I crank the motor
  #22 (permalink)
Old 10-26-08, 10:41 PM
Casino Cash: $4382
If it pumps up to 40 lbs when the key is turned on your getting enough fuel pressure to start the motor. it runs for about 5 seconds when turned on... if the pump does not pump while cranking thats a different problem.. you have to check to know if the injectors are getting a pulse.. because you said it did fire up when you poured fuel in the throttlebody I'm betting your not getting a pulse....The sensor or reed switch on the distrubitor gives the ECM the pulse for the injectors ...these almost never fail....a bad connection or bad ground could be it.... or the ECM has failed...Let us now about the pulse...
efi, eldo, start, wwont
