76 Deville Wont Run
Results 1 to 4 of 4
500, 472, 425, 368 Discussion, 76 Deville Wont Run in Cadillac Engine Discussion; New Carb, Fresh Fuel, Getting Spark, Timing Close Enough To Fire, Thinking About Rebuilding The Hei. Car Sounds Like Running ...
    byrd's Avatar
    byrd is offline Cadillac Owners Member
    May 2004
    12
    76 Deville Wont Run
    New Carb, Fresh Fuel, Getting Spark, Timing Close Enough To Fire, Thinking About Rebuilding The Hei. Car Sounds Like Running On Two Cylinders Then Dies Anyone With Sugestions??????????
    lux hauler is offline Cadillac Owners Connoisseur
    Jan 2003
    Ohio
    46
    1,258
    Re: 76 Deville Wont Run
    Did it run before the new carb? Have you changed anything other than the carb....moved/removed dist., removed plug wires etc.?
    Dead Sled's Avatar
    Dead Sled is offline Cadillac Owners Connoisseur
    Jan 2003
    South of a Cornfield, IA
    1,380
    got fuel pressure?
    byrd's Avatar
    May 2004
    12
    Car Started Gradualuy Running Bad, I Bought Rebuilt Carb And Still Running Bad. When I Was Taking Old Carb Off, I Bent Fuel Line Slightly, It Might Be Restricting Flow. Havent Checked Pressure Though
  7. Remove Advertisements
