1968 472/500 Quadrajet EGR crossover Baffle?
Results 1 to 4 of 4
500, 472, 425, 368 Discussion, 1968 472/500 Quadrajet EGR crossover Baffle? in Cadillac Engine Discussion; Does anyone know where to get the proper quadrajet base gasket(s) for a 1968 472? The a manifold has the ...
    sgtbilkodle is offline Cadillac Owners Member
    Automobile(s): Cadillac
    May 2008
    1
    Does anyone know where to get the proper quadrajet base gasket(s) for a 1968 472? The a manifold has the EGR crossover channels in it and no off-the-shelf gaskets seem to match up. I would prefer to seal off the exhaust crossover channels that are in the manifold-carb mounting surface to reduce temp of carb and the slew of . I have found that chevy's use a similar setup in 69/69 but it seems all the pictures i find show a different layout for the channels.
    any advise is much appreciated.
    Thanks in advance
    sgtbilko
    cadillacbart is offline Cadillac Owners Fanatic
    Automobile(s): 1968 DeVille Convertible (current project)
    May 2005
    Thornton, CO
    157
    Re: 1968 472/500 Quadrajet EGR crossover Baffle?
    Are you talking about the metal shim that goes under the carb with the gasket? If so, I was missing mine a couple years ago and could not find a "new" one. I believe I got mine used from Jeff at Willington Cadillac. The car simply would not idle properly without it.
    guidematic's Avatar
    guidematic is offline Cadillac Owners Fanatic
    Automobile(s): 70 Fleetwood, 87 and 90 Brougham, 94 Fleetwood
    Sep 2004
    Kitchener Ontario, Canada
    215
    If I understand you correctly, you want to plug off the exhaust heat passages at the base of the carb.
    If you live in a permamnantly warm climate, you may get away with it, but if you ever plan on driving the car in cooler climates doing this will cause more grief than it's worth. They are there to provide heat to the base of the carb and prevent carburetor icing in cool wet temperatures, and also aid in warmup.
    What could happen will be persistent stalling and very poor fuel economy. Be wary of any modifications from stock. Understand the system you wish to remove and the results before you do it.
    Mike
    Dirtywaterdiver's Avatar
    Dirtywaterdiver is offline Cadillac Owners Fanatic
    Automobile(s): 1968 Convertible
    Jul 2010
    Boston MASS
    268
    I tried this replacement because my carb leaks and the idle is messed because of it. I got the FEL-PRO Base Gasket 60010 and the metal shim from Carbs unlimited part G796. However they do not match up.
    How is this supposed to work?
    How are the positioned?
  7. Remove Advertisements
