Results 1 to 5 of 5
Thread: carburetor fuel filter thread damaged
    May 2004
    6
    Angry carburetor fuel filter thread damaged
    I replaced the fuel filter on my 425 motor the other day and when I put it back in it was at an angle at now it leaks badly. I also must have lost the little ring that is supposed to go around the fitting to "lock" it in place. I tried to get a thread repair kit from autozone but it was too small. I also tried teflon tape but no good. What are my options? I cannot find a gasket big enough to go around this 1" fitting nor can I find a thread repair kit big enough. It's been suggested that I epoxy the filter housing in place and install an inline filter. Please help!
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: carburetor fuel filter thread damaged
    If you stripped the threads on the carb itself, I don't know if you can do much to fix that! I always put an inline fuel filter on my Q-jet Cads, so yes, you could epoxy the fuel inlet into the carb, then hook up an inline filter.
    The gasket you are missing is in carb rebuild kits, you could try and get one from there, or try a junkyard for a used one.
    Jul 2003
    San Clemente, CA
    30
    989
    inline filter.
  5. #4
    May 2004
    6
    Thanks for the responses guys, I ended up getting some thread sealant and tightening it down. Seems to have done the trick.
  6. #5
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Glad to hear you fixed it, but keep an eye on it. Gasoline eats through a lot of stuff, so make sure it doesn't start leaking again on a hot engine.
  • You may not post replies
