'81 DeVille Diagnostic test?
Results 1 to 2 of 2
500, 472, 425, 368 Discussion, '81 DeVille Diagnostic test? in Cadillac Engine Discussion; On my '81 DeVille when I go to run the diagnostics test it shows 30 as the only code, 88 ...
    rollerz70 is offline Cadillac Owners Fanatic
    May 2004
    105
    On my '81 DeVille when I go to run the diagnostics test it shows 30 as the only code, 88 and 70 meaning the beging and end of it. When I start the car it starts and then after a few seconds trys to die until I put my foot on the gas a little. Is this the ISC or TPS? How can I test each to see what it is?
    After I get it to stop wanting to die, only does it for about 30 seconds when cold, it idles and runs just fine. Any thoughts? Thanks
    Pianoman72 is offline Cadillac Owners Member
    Apr 2004
    64
    Re: '81 DeVille Diagnostic test?
    This guy talks about how he fixed his code 30 but it's probably not as detailed as you would like...
    http://www.larryscars.com/81cad.html
