Anyone ever see one of these?
Results 1 to 5 of 5
500, 472, 425, 368 Discussion, Anyone ever see one of these? in Cadillac Engine Discussion; This sleeve was inside the header pipe on my Eldorado. It looks very restrictive. No wonder the manifold was cracked ...
    kevin666's Avatar
    kevin666 is offline Cadillac Owners Member
    May 2006
    49
    This sleeve was inside the header pipe on my Eldorado. It looks very restrictive. No wonder the manifold was cracked so bad with all that heat being restricted inside of it.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: Anyone ever see one of these?
    Yeah, there is something strange there. I have seen cracked manifolds only very rarely. Will the header pipe bolt on without that reducer thing? I would definitely try to elimnate it somehow. I hope an Eldo owner can chime in.
    yorfate is offline Cadillac Owners Member
    Automobile(s): 1969 Cadillac FltSuperior Sovereign Hearse, 2003 Deville DTS
    Jan 2012
    28
    6
    That looks like a quick fix for an absent heat riser valve. No good..
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    That sleeve looks like it may have been inserted into the manifold to correct the cracked seal seat of the manifold. A quick fix of sorts.
    Roadmaster75's Avatar
    Roadmaster75 is offline Cadillac Owners Member
    Automobile(s): 1978 Eldorado Biarritz
    Feb 2012
    Illinois
    59
    HI
    FYI
    I just pulled the same gizmos out of a 76 Eldo motor that has not been opened up in
    the past. And, yes the driver's side manifold is cracked, too!
    mike
  8. Remove Advertisements
