| 500, 472, 425, 368 This forum is to discuss the old big block Cadillac engines. | Cadillac Forums: carb compatability
05-02-04, 09:56 PM
|  | Cadillac Owners Member | | | | | carb compatability im new to the site, i think its great!
i need info on compatability with the 500 engine, im looking for the cheapest options |
05-02-04, 10:18 PM
| | Cadillac Owners Connoisseur | | Join Date: Jan 2003 Location: Ohio Age: 39 | | | Re: carb compatability Welcome to the site.
Do you have a carb now? |
05-03-04, 11:26 PM
|  | Cadillac Owners Member | | | | | Re: carb compatability yes, it is the stock q-junk, or q-jet |
05-04-04, 12:16 AM
|  | Got Torque? Cadillac(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20 | | Join Date: Aug 2003 Location: Bucks County, PA Age: 22 | | | Re: carb compatability Any spreadbore will work with the manifold on there now. You will need an adapter to use a square bore carb. Did you have something in mind? 650-750 cfm would be your best bet. I have an Edelbrock Performer with an electric choke on my Cad. (also note I kept that goofy air cleaner stud, so I could use my offset factory air cleaner. Important because it clears the A/C compressor.)  |
05-04-04, 12:33 AM
|  | Cadillac Owners Enthusiast | | Join Date: Jul 2003 Location: San Clemente, CA Age: 22 | | | Re: carb compatability cute carb. We match. I also have that same ratchet. You need to paint some stuff under the hood. Very clean though, dave. |
05-04-04, 07:35 PM
|  | Cadillac Owners Member | | | | | Re: carb compatability thanks for the help |
05-04-04, 10:27 PM
| | Cadillac Owners Connoisseur | | Join Date: Jan 2003 Location: Ohio Age: 39 | | | Re: carb compatability Many people believe that for street performance/fuel economy, the Q-Jet can't be beat.
You already have the carb.......I'd use it. That'd be the cheapest route, even if it needs work. I just sent my Q-Jet out for a performance build.......shouldn't cost me any more than $300. That's less than many new carbs.
The Carb Shop in Ontario, CA is doing mine. |
05-05-04, 03:00 PM
|  | Cadillac Owners Member | | Join Date: May 2004 Location: Caracas, Venezuela Age: 41 | | | Re: carb compatability Rebuilding the original Q-Jet is probably your best bet. Check here first: http://www.carbs.net/quadrajet.asp Then go out to get a price on a comparable one and you'll be surprised. |
05-05-04, 03:04 PM
|  | Cadillac Owners Member | | Join Date: May 2004 Location: Caracas, Venezuela Age: 41 | | | Re: carb compatability Jeremy, nice ride. I just got a 1970 Fleetwood Brogham I'm planning to resto-mod. I'm calling it the Fleetwood Anhialator. |
05-05-04, 11:48 PM
| | Cadillac Owners Member | | | | | Re: carb compatability I just put a edelbrock 750 on my 1968 472 ,it runs great. I bought it at Autozone it cost $260 dollers and its brandnew. I think it was a good buy. Hope you have great luck with your carb.  |
05-09-04, 08:24 PM
|  | Cadillac Owners Fanatic | | Join Date: Mar 2004 Location: Bluff Creek | | | Re: carb compatability Voodoo I'm also running a 472 in a 69 Caddy hearse and looking for a new carb. Would you recomend the Edelbrock you purchased? Just can't seem to get any excelleration out of my old Q-jet. I know a rebuild would help but looking at all options. How was the change over? Everything match up? Vacuume line ins easy to locate on the Edelbrock? |
07-09-04, 12:02 PM
|  | Cadillac Owners Member | | Join Date: Nov 2003 Location: Cypress, TX Age: 28 | | | Re: carb compatability Yeah, let us know how easy the swap from the stock q-jet to an Edelbrock 750 is, please. I'd like to do to the swap on my '68 Coupe but I'm no great mechanic (or even a mediocre or bad mechanic, for that matter) and don't want to run into big probs that I can't deal with myself. I've found rebuilt q-jets for about $130 but if you can get the Edelbrock for that cheap, might as well. My dad keeps houding me to do the switch too. He's, "never had anything but good luck from Edelbrock, son..." Is the change to electronic choke hard to do? What about the throttle linkage? Thanks! |
07-09-04, 05:26 PM
|  | Cadillac Owners Fanatic | | Join Date: Mar 2004 Location: Bluff Creek | | | Re: carb compatability Real easy change out! Use the hot wire from your kickdown switch on your old Q-Jet for the power lead to electric choke. You will no longer need this kickdown set up or the dashpot so remove it. These are on the throttle linkage side of the Q-Jet. All the install directions are in the box. Vacuum lines, you'll need a tee splitter. When looking directly at the front of the carb on the car the right vacuum port is the one you want to use. Take a small piece of hose come off that port on the carb, a couple of inches will do, install the tee. Now take the vacuum line from your transmission ( should be on the back of the Q-Jet not the big one that goes to the power brake booster the smaller one) hook it into one side of the tee and the vacuum line coming from the dist. hook into the other side of the tee.The PCV hose goes to big center port on the front of the carb. Plug off the other port on the left on the carb. there should be some plugs included with your new carb. The tee splitter is included as well. Be sure to check for this before leaving the parts store to prevent a trip back. Also I would suggest buying all new vacuum lines. Look at the sizes you need and get some. They're cheap. The reason for this is that a few will have to be lengthened in order to reach. Especially the one from the transmission as it now has to go to the front of the carb. as compared to the back on the Q-Jet. Hook the bigger line from the power brake booster to the back of the carb just like on the Q-Jet. You may need to buy the screw in adapter for this. My carb. did not come with one. Just look at the back of the carb if there is just a threaded hole you'll need to ask for the adapter. I put a 1411 Edelbrock on my 472 and love it. Right out of the box and bolted it on with no adjustments necessary. The previous instructions were for the 1411 Edelbrock carb. You will need to buy the adapter plate for an additional $30.00 but that all goes on very easy. Also ask for the carb. mounting stud kit. Your old bolts won't work because of the thickness of the adapter plate. Make sure all your gaskets between the manifold and the adapter plate are in good shape and line up to prevent any air leaks. There should be a thin metal gasket located under the Q-Jet when you remove it. This is critical when installing the adapter plate. It must be positioned correctly with the other gasket to prevent the air leaks. When you have it apart and look you'll see what I mean. All in all a real easy change out. Taking your time 1 to 2 hours. Only four bolts holding your old carb in place. |
07-10-04, 05:39 AM
|  | Cadillac Owners Enthusiast Cadillac(s): `65 DeVille Convertible´67 Eldorado,´96 Eldorado,97 Wrangler | | Join Date: Apr 2003 Location: Tallinn, Estonia Age: 41 | | Re: carb compatability Quote: |
Originally Posted by 68CoupeDeVille ...I've found rebuilt q-jets for about $130..... | Can you tell, where i can buy q-jet for this price? I have rebuild kit for my original carb(´67 429 Eldo), but its always better to use professionally rebuilt item.
Thanks! | | Cadillac Discussion Tools | | |
Censor is ON | | | |
