Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > 500, 472, 425, 368
500, 472, 425, 368 This forum is to discuss the old big block Cadillac engines.
Cadillac Forums: 472/425 intake swap: which gasket set?
Old 11-12-07, 12:30 PM
Cadillac(s): 1976 Fleetwood Brougham, 1979 Sedan deVille
View bicentennialcadillac's Photo Album
Casino Cash: $4480
Question 472/425 intake swap: which gasket set?
I'm nearing time to put the '68 472 intake on my '79 425. I haven't seen this covered elsewhere - which gasket set should I use, the '68 or the '79?
The gasket sets look identical, but partsamerica.com insists that they're different. Thanks in advance for any guidance provided.
  #2 (permalink)
Old 11-22-07, 11:15 PM
caddydaddy's Avatar
Cadillac(s): 94 Deville, 2000 STS, 2005 Escalade 2WD
View caddydaddy's Photo Album
Casino Cash: $2492
Re: 472/425 intake swap: which gasket set?
The 472 has larger ports, so with either gasket set, you're not going to match up perfect. If you open the ports to match on the 425 heads, then I'd use the 472 gaskets.
  #3 (permalink)
Old 11-24-07, 03:23 PM
Night Wolf's Avatar
Cadillac Owners Master
Cadillac(s): Jeep: '05 TJ Sport 6spd BMW: '90 325iC & '92 318iC both 5spd
View Night Wolf's Photo Album
Casino Cash: $13442
IIRC I used the '68 472 intake manifold gasket set when I swapped it over on my stock 425... I never had problems with it, we did RTV the 2 rubber gasket things tho.
  #4 (permalink)
Old 12-03-07, 01:28 AM
Cadillac(s): Cadillac
View Finalman's Photo Album
Casino Cash: $375
How much of a difference does just the 472 manifold make, and, does it have to be an older style manifold?
  #5 (permalink)
Old 12-05-07, 07:30 PM
Night Wolf's Avatar
Casino Cash: $13442
it made a very noticeable difference, my carb was also rebuilt at the same time.
I know the '68 472 intake manifold is the best flowing of factory manifolds, and with it opened up as mentioned, it'll match the Edelbrock intake manifold for flow until 5,500-6,000RPM or so, well beyond even a mildly modded BB Cad (factory redline is around 4,000RPM) But there is no hood clearance issues, you can keep A/C, it's alot cheaper and looks stock
  #6 (permalink)
Old 12-05-07, 08:23 PM
caddydaddy's Avatar
Casino Cash: $2492
More like 5,000 RPMs. Even the HP peak of the 472 is at 4,400 RPMs. The rocker arm retainer clips of the T pedestal valvetrain is what fails at high RPMs. That occurs when you try and rev them over 5,000 RPMs.
Tags: , , , ,
gasket, intake, set, swap
