1968 472 HEI SWAP, Big time Problems!
Results 1 to 4 of 4
Like Tree1Likes
  • 2 Post By Angela Desmond
500, 472, 425, 368 Discussion, 1968 472 HEI SWAP, Big time Problems! in Cadillac Engine Discussion; The motor is a 1968 Cadillac 472.I've set #1 to TDC(compression stroke),dropped the distributor in and set my cap up ...
    EvilTrucks is offline Cadillac Owners Member
    Apr 2004
    Talking1968 472 HEI SWAP, Big time Problems!
    The motor is a 1968 Cadillac 472.I've set #1 to TDC(compression stroke),dropped the distributor in and set my cap up accordingly.Still,nothing but backfiring through the carb&not starting.My CHILTON book showed #1 at about 1 o'clock;this was for 68's only.Should the vacuum adv.be pointing in any certain direction?
    Imprl59 is offline Cadillac Owners Fanatic
    Jan 2004
    300
    Re: 1968 472 HEI SWAP, Big time Problems!
    Are you sure you have timed it with #1 at TDC on the compression stroke? Sounds like you are 180 degrees off.
    Steve B.
    Angela Desmond is offline Cadillac Owners Fanatic
    Apr 2003
    new windsor new york
    60
    193
    Well, it's obviously out of time if it's backfiring. Of course, you remembered that Caddy #1 is on the passenger side, unlike other motors...When you put the dist. in, make sure the star wheel on the dist. is exactly on the firing point. A little one way or the other and you'll be pretty far off. Sometimes, removing a distributor can move the oil pump position slightly and you'll think you're dropping the new dist. in exactly as the old one came out, but you'll be a little off, that's why you should check the star wheel. Face the vacuum adv. in pretty much the same direction as the dist. you took out.Hope that helps some...
    Apr 2004
    Thumbs upRe: 1968 472 HEI SWAP, Big time Problems!
    I,m gonna do just that,thanks for the input.Hopefully my next post'll say running 68 cad motor.....
  7. Remove Advertisements
