1970 Eldorado 14,400ORIG miles (TimeCapsule)
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
500, 472, 425, 368 Discussion, 1970 Eldorado 14,400ORIG miles (TimeCapsule) in Cadillac Engine Discussion; Guys, I'm about to drop $20,000 on the 1970 Eldorado, Cinamon Firemist, with Optional SUNROOF. Now this is the REAL ...
    BAugust is offline Cadillac Owners Member
    Automobile(s): 1970 Eldorado
    Apr 2004
    Reading PA AREA (Not Reading)
    12
    Question1970 Eldorado 14,400ORIG miles (TimeCapsule)
    Guys,
    I'm about to drop $20,000 on the 1970 Eldorado, Cinamon Firemist, with Optional SUNROOF. Now this is the REAL DEAL kept in Climate controlled Storage for over 30 years it is Truly Unbelievable.
    Now, as far as Performance, what did this car ORIGINALLY run in the quarter Mile, 15's?? Low 16's??
    What might be my problem areas, the Radiator has been flushed several times through the years, the air was just charged and blows very cold.
    Thanks in Advance!!!
    JJhomer83's Avatar
    JJhomer83 is offline Cadillac Owners Connoisseur
    Sep 2003
    Bucks County, Pa
    34
    1,805
    Re: 1970 Eldorado 14,400ORIG miles (TimeCapsule)
    Quote Originally Posted by BAugust
    Guys,
    GO FOR IT it sounds like a GREAT deal
    Apr 2004
    12
    Gee ..Thanks... But what I really need are some answers to my questions on it (above)?
    Guys???
    JJhomer83's Avatar
    Sep 2003
    Bucks County, Pa
    34
    1,805
    Guys???
    ohhh sorry about that
    1/4 time would be a guess around 17ish
    now for problem areas i would look for rust on the car and cracked lines. Remove lights check under the car, check the exhaust etcc....
    hopefully someone with more knowledge will chyme in
    Apr 2004
    12
    Quote Originally Posted by JJhomer83
    Not to be unappreciative, but yes. And as far as RUST, no one would shell out 20k without seeing DOZENS of digital photo's of the Undercarriage as well as every other Nook & Cranny of the car, which is SHOWROOM quality. As far as 1/4 mile times, this year 1970 ELDORADO is held up as the QUICKEST of ALL
    the older Cadillacs, so I would HOPE its AT LEAST a high 15, if not faster!!
    Anyone?? Bueller??
    JJhomer83's Avatar
    Sep 2003
    Bucks County, Pa
    34
    1,805
    1979 Cadillac Eldorado (Gas) 1/4 = 17.9
    not what your look for but this is what i found
    Imprl59 is offline Cadillac Owners Fanatic
    Jan 2004
    300
    Your in the right neighborhood for performance specs. I can't find any specs online but it is a damn fast car for a luxury liner.
    Things to worry about:
    Gas tank - Probably full of crud. I would pull it and have it boiled out.
    Rubber gas lines - Current fuel specs will make quick work of old rubber lines and fuel pumps. Go ahead and replace them with current spec rubber.
    Rubber on the engine - Replace all the vacuum lines hoses and belts. Age will be getting to them.
    Gaskets - The gaskets will probably start leaking as soon as it goes back in service.
    Freeze plugs - If the engine didn't have fresh antifreeze in it all these years the freeze plugs will rust. They could bust out when you get going.
    The shaft seal on the compressor will probably die in short order. You can have just the seal replaced when/if it goes out.
    I would change the tranny fluid and the differential fluid.
    Brakes will also be a sore spot if it wasnt driven on a regular basis. Count on new MC, wheel cylinders/calipers and new rubber hoses.
    After doing this several times I would say count on spending another 2k getting it ready to go and you should easily be ready to go for another 100k after that. Sounds like a beautiful car. Please put some pics up on the web and let us know where they are when you can.
    Steve B.
    Elvis's Avatar
    Elvis is offline Cadillac Owners Master
    Automobile(s): '05 Expedition
    Jan 2003
    52
    7,651
    Imprl59 just made a post worthy of the #1 spot in the FAQ.
    Can I get an Amen?
    ThomasO's Avatar
    ThomasO is offline Cadillac Owners Fanatic
    Mar 2004
    188
    AMEN
    Apr 2004
    12
    Great, but mines a 70 NOT 79!!!!!!!!! "Should be more like a 15.8-16.2 with the 400hp!
    So.....ANYONE KNOW!!
    By the way, thanks Imprl59, thats EXACTLY what I was looking for! Pics coming shortly!
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Well, a 70 Eldorado weighs 4630 pounds, and has a high compression 500. Cad company got 323hp and 504 ft.lbs torque from a bone stock high compression 500. The 400hp/550ft.lb claim was inflated quite a bit because they didn't really have a standard way of calculating power until I think it was 73.
    I don't know how reliable any of the online 1/4 mile ET calculators are, but most say you're looking at a mid-high 15 second 1/4.
    ThomasO's Avatar
    Mar 2004
    188
    Why would anybody want to take this car, a $20,000., mint condition, 4,000 lb., 1970 Cadillac, to a dragstrip and beat hell out of it?
    Guys,
    MMNineInchNails's Avatar
    MMNineInchNails is offline Cadillac Owners Enthusiast
    Jul 2003
    San Clemente, CA
    30
    989
    because it's badass.
  16. #14
    Ralph's Avatar
    Ralph is offline Cadillac Owners 10000+ Posts
    Automobile(s): Cadillac
    Mar 2003
    Saskatchewan, Canada
    16,105
    Sounds like a beauty. When my Dad sold his 11,000 mile 1971 442 w-30 Olds, the only thing that happened was the waterpump gasket becomming brittle and cracking up with old age causing a bad leak. It STILL has the original firestone Wide O Ovals on it! So some rubber seems to stand the test of time. (safety may be another factor) All of my Dad's cars are fairly low mileage, and as long as it was ran and possible driven every so-often it might be ok. there are no guarentees.
    I am curious if you have the original tires, hoses, etc on it if you buy it. Something like this could be in a museum, so don't race it, worship it! It is an important part of automotive history that will likely NEVER be found again in this condition! If you feel the need to go racing, I hope you buy a Trans Am to beat the crap out of.
  17. #15
    ThomasO's Avatar
    Mar 2004
    188
    OH! I see. Well that makes since. Thanks NIN for the enlightenment. .
    Quote Originally Posted by MMNineInchNails
  18. Remove Advertisements
