Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > 500, 472, 425, 368
500, 472, 425, 368 This forum is to discuss the old big block Cadillac engines.
Cadillac Forums: 1976 Sedan Deville 500ci oil capacity
Old 05-22-07, 10:13 AM
Cadillac(s): Cadillac
View WEASEL's Photo Album
Casino Cash: $250
I just rebuilt the 500 in my 1976 Sedan Deville. Had an issue with the dipstick tube and replaced it with a new one. Unsure if it is the correct one. I never new how much oil this tank would hold from the beginning, si I just want to make sure I don't under or over fill it. Just need to know how much oil it holds. It has the stock oil pan on it.
Thanks.
  #2 (permalink)
Old 05-22-07, 01:44 PM
Cadillac(s): 1976 FLEETWOOD brougham
View fleetwood76's Photo Album
Casino Cash: $7246
Re: 1976 Sedan Deville 500ci oil capacity
Hello!
A stock -76 500 RWD holds 5 US quarters if the filter is changed and 4 us quarters if no filter changed. I guess your engine is dry after the rebuild and would need 5 quarters.
jolle
  #3 (permalink)
Old 09-06-07, 10:00 PM
Casino Cash: $250
Thanks a ton. Our parts department must have gave the wrong dipstick tube, she has 5 qts in her and only touches the very bottom of the dipstick.
  #4 (permalink)
Old 09-15-07, 01:23 PM
caddydaddy's Avatar
Cadillac(s): 94 Deville, 2000 STS, 2005 Escalade 2WD
View caddydaddy's Photo Album
Casino Cash: $2492
You could just cut the top of the dipstick tube with a tubing cutter, and calibrate it to the 5 quarts that you have in it now.
  #5 (permalink)
Old 09-16-07, 12:34 AM
View brihill18's Photo Album
Casino Cash: $765
What about a 76 500 out of an elderado? Is that still the same 5 qts?
  #6 (permalink)
Old 09-16-07, 12:54 AM
caddydaddy's Avatar
Casino Cash: $2492
That engine uses a different oil pan, so it may be different.
  #7 (permalink)
Old 09-16-07, 12:14 PM
Casino Cash: $7246
Hello.
According to the 1976 owners manual page 80, (where I got the numbers for the RWD cadillacs with 500 engines) is the engine oil capacities for the Eldorado- 5 u.s. Qts without filterchange and 6 u.s Qts with filterchange.
jolle.
  #8 (permalink)
Old 09-21-07, 01:28 AM
View ShokleyMobile1972's Photo Album
Casino Cash: $250
The 1976 Deville I had only held 3 quarts. I think there must have been a lot of smudge in the pan.
  #9 (permalink)
Old 09-21-07, 07:47 AM
caddydaddy's Avatar
Casino Cash: $2492
Wow, somethings not right there!
  #10 (permalink)
Old 06-18-08, 04:13 AM
"75" Coupe's Avatar
Cadillac(s): "75" Cadillac Coupe Deville
View "75" Coupe's Photo Album
Casino Cash: $990
Cool Re: 1976 Sedan Deville 500ci oil capacity
My "75" holds 6 quarts with a filter change.
Factory oil pan and I am almost certain all 500's are the same...
  #11 (permalink)
Old 06-18-08, 07:53 PM
Cadillac(s): 95 fleetwood 81 deville
View drmenard's Photo Album
Casino Cash: $4332
Make sure you use a oil that will not distroy your flat tappet cam.. Over the road gasoline motor oil has had the additives that are nessasary for a flat tappet cam taken out..The additive is not good for sensors and maybe cat. Best to use a racing oil such as VR1 valvoline racing oil..NAPA has it...
Tags: , , , , ,
1976, 500ci, capacity, deville, oil, sedan
