1984 fleetwood 500
Results 1 to 4 of 4
500, 472, 425, 368 Discussion, 1984 fleetwood 500 in Cadillac Engine Discussion; Is it possible, with out to much modification to put a cadillac 500 in a 1984 fleetwood....
    cadillacdeville's Avatar
    cadillacdeville is offline Cadillac Owners Fanatic
    May 2004
    Longview Tx
    31
    250
    1984 fleetwood 500
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: 1984 fleetwood 500
    That all depends on your definition of too much modification.
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,181
    you can put a 500 in your 84 fleetwood ... It is a bolt in...All the parts can be taken off a 77-79 full size RWD caddy...It would be best to use a TH400 transmission... you can use your rearend with a little drive shaft work, but maybe best to use a rear off a donor car..If you get youself a donor car everything you need is there...when you take out the computer , all you have to do is ground one wire and the climate control will work just fine...
    Wheelman322's Avatar
    Wheelman322 is offline Cadillac Owners Enthusiast
    Automobile(s): 1979 Coupe Deville, 1995 FWB & 6 Other Non-Cadillacs.
    Nov 2003
    New Jersey
    755
    Quote Originally Posted by drmenard View Post
    ...all you have to do is ground one wire and the climate control will work just fine...
    Just curious if this means I can add an electronic control head to my 78 if I ground this wire?
  7. Remove Advertisements
