Horrible Squeking
Results 1 to 10 of 10
500, 472, 425, 368 Discussion, Horrible Squeking in Cadillac Engine Discussion; I Have A Horrible Squeking Sound Inside My Cab, Found Out It Is My Speedo Tube. Anyone Ever Grease That ...
    THE1ANDONLY's Avatar
    THE1ANDONLY is offline Cadillac Owners Member
    Automobile(s): Cadillac Coupe Deville
    Nov 2006
    Southern California
    11
    Horrible Squeking
    I Have A Horrible Squeking Sound Inside My Cab, Found Out It Is My Speedo Tube. Anyone Ever Grease That Tube Before? If So How Was It? Any Troubles? Tips? (1970 Coupe De Ville)
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: Horrible Squeking
    There is a tool which will allow the speedo cable to be greased by unscrewing it from the transmission end. It adapts to a zirc fitting. You have to go very slowly while greasing. Use a hand pump otherwise the cable will blow apart. Alternative is to pull the cable center out, grease, reinstall.
    limousine rider's Avatar
    limousine rider is offline Cadillac Owners Member
    Automobile(s): 1971 fleetwood, series 75<----Antique Land Yatch
    British Columbia, Canada
    66
    Quote Originally Posted by The Ape Man View Post
    He can also replace it with a new one if the old one is to far gone.
    Nov 2006
    Southern California
    11
    I Was Going To Pull My Dash Apart But Did'nt Know What I Was Getting Into. So Is There A Zirc Fitting On My Tranny? If So Is That All That I Grease (what Kind Of Grease)?
    Feb 2005
    Southern NJ
    54
    2,096
    No. It's a tool that screws into the cable at the lower end.
    Nov 2006
    Southern California
    11
    Where Can I Find That Tool?
    Brother_B's Avatar
    Brother_B is offline Cadillac Owners Fanatic
    Automobile(s): 1969 Coupe DeVille, 1972 Sedan DeVille
    Jan 2007
    Neptune Beach, FL
    44
    159
    Good luck finding that tool. I highly recommend that you try to find it before you take the dash apart. I replaced my speedo cable recently, and I haven't been able to get it working again yet. The hugest pain in the ass was the part behind the dash. I ended up dismantling the radio and heater controls before I could get enough access to get to the end that connects to the gage. (Then again, I've got Gumby fingers.) If you can get away with just removing the tranny end of the cable and pump grease in that way, do it. As for the type of grease, the new cable came with some special "speedo grease". No idea what exactly it was, it was just called speedo grease. All I know is it was yellowish-brownish. Maybe you can buy some. Back when I did mine, looking around a little bit, I found out that white lithium grease or wheel bearing grease have been used. Now that I think about it, I bet grease may be my problem, so I am going to try to find this tool as well.
    Koooop's Avatar
    Koooop is offline Cadillac Owners Master
    Automobile(s): 300 SRT8, 392 cubic inches of tire smoking power!
    Jan 2005
    So Cal
    53
    8,189
    The Cruise Control can cause the squeak as well. You'll probably notice the speedo needle is bouncing as well when the squeak is going. My Eldo is doing it, it sucks. I gonna start by having the cable lubed, if that doesn't work then I may just bypass the cruise with a new standard speedo cable for a car w/o cruise.
    BluEyes's Avatar
    BluEyes is offline Cadillac Owners Enthusiast
    Automobile(s): 1970 Sedan deVille hardtop
    Feb 2005
    595
    If the car has cruise and the squeaking is definately from inside the cabin, then greasing the lower cable at the trans won't help, you'd need to grease the upper cable that runs from the cruise controll 'brain' to the dash.
    As for pulling the dash apart, I've had my '70 apart a few times and it is by far the easiest dash I have ever seen to take apart and together. Grab a FSM off Ebay and it will be really easy as long as you have a reasonable mechanical aptitude.
    cadillacmike68's Avatar
    cadillacmike68 is online now Cadillac Owners Connoisseur
    Automobile(s): 68 DVC, 96 FLTWD Brg, 09 STS N* Platinum, 11 CTS Premium
    Jan 2005
    Left the desert - Back in FL
    55
    1,300
    The 1970 is a lot easier to take apart then the 69 whcich itself is many times easier than the 68s. I know - have been in all three. They didn't make the 68 to be taken apart easily. Just wait until you have to change a front side marker or cornering light!!!
  13. Remove Advertisements
