Gap setting for 472 points
Results 1 to 8 of 8
500, 472, 425, 368 Discussion, Gap setting for 472 points in Cadillac Engine Discussion; Whats the recomended setting for points on a 472? .08 <----- Gap ? whats your input ?...
    limousine rider's Avatar
    limousine rider is offline Cadillac Owners Member
    Automobile(s): 1971 fleetwood, series 75<----Antique Land Yatch
    British Columbia, Canada
    66
    QuestionGap setting for 472 points
    .08 <----- Gap ?
    whats your input ?
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: Gap setting for 472 points
    Quote Originally Posted by limousine rider View Post
    .08 <----- Gap ?
    whats your input ?
    IIRC .017 . Tune-up specs are on this board.
    Brother_B's Avatar
    Brother_B is offline Cadillac Owners Fanatic
    Automobile(s): 1969 Coupe DeVille, 1972 Sedan DeVille
    Jan 2007
    Neptune Beach, FL
    44
    159
    Chiltons lists .016" for the point gap. More importantly, set the dwell angle to 30* (28* to 32*), assuming the car is running and you have a dwell meter. Also if it is running, you can try the following alternative method from my shop manual: (1) Turn adjusting screw in (clockwise) until engine begins to msifire. (2) Turn wrench 3/4 turn (270*) in opposite direction (counterclockwise), and then turn clockwise 1/4 turn (90*) to obtain proper gap and dwell.
    Feb 2005
    Southern NJ
    54
    2,096
    You set the points then always check dwell. Just setting the gap is half the job. The dwell can be set with the engine cranking and the secondary of the coil grounded if you are quick enough. In other words the car doesn't even have to be running..
    66
    Thanks, worked out real good !
    cadillacmike68's Avatar
    cadillacmike68 is offline Cadillac Owners Connoisseur
    Automobile(s): 68 DVC, 96 FLTWD Brg, 09 STS N* Platinum, 11 CTS Premium
    Jan 2005
    Left the desert - Back in FL
    55
    1,274
    Get a tach / dwell meter at Sears or most auto shops - get an old style one that is meant for points / condenser. You also need a 1/8" allen wrench. Lift up the window on the distributor cap and you can adjust the points while the engine is running! Note this only applies to GM V8s from 1968 to 1974 after which they went to HEI.
    Yet another example of GM engineering triumphs in the late 60s!
    66
    Quote Originally Posted by cadillacmike68 View Post
    Great information! what should the dwell #s range? 800 idle rpm?
    Jan 2005
    55
    1,274
    Please read my last post in this thread:
    http://www.cadillacforums.com/forums...rpms-park.html
    I could be all wrong by the way, but I'm probably not ...
  11. Remove Advertisements
