"Lazy" transmission
Results 1 to 10 of 10
500, 472, 425, 368 Discussion, "Lazy" transmission in Cadillac Engine Discussion; Hi to everyone, here is my problem, hoping someone of you can give some suggestions. My car, a 1976 Cadillac ...
    lucaitaly is offline Cadillac Owners Member
    Automobile(s): 1976 Calais Sedan
    Apr 2007
    Italy, Florence area
    38
    "Lazy" transmission
    Hi to everyone,
    My car, a 1976 Cadillac Calais, until some weeks ago was working fine. But....one morning didn't want to move at all.
    So, here is what happened and what actually happens.
    After turning the engine on the car doesn't move, at all. Only after several minutes of warming up, about 10, only the reverse starts working. After some more minutes even the other gears start working. Practically, when engine is cold the car doesn't move.
    I got the impression that it is a transmission pressure problem, maybe. Fluid level is fine, checked and checked again.
    Before getting in a big work dismantling the transmission and having it checked, I would like to have some advices by this forum
    Sorry for my poor english, hope you can understand what I wrote.
    Thanks for your attention.
    Luca
    danomac is offline Cadillac Owners Member
    Automobile(s): 1981 Cadillac Coupe DeVille
    Mar 2007
    Vancouver, BC Canada
    40
    51
    Re: "Lazy" transmission
    Given those symptoms, it sounds like there's gunk possibly in the transmission that thins out as the transmission fluid warms up.
    I'm not a transmission expert though.
    eldorado99's Avatar
    eldorado99 is offline Cadillac Owners Connoisseur
    Jul 2005
    29
    1,221
    Hey danomac! always nice to see another west coaster! There aren't many of us on these boards. Most of the Canucks on here are from Ontario.
    Yes I wish I knew more about transmissions so I could help you, but I'm sure someone here will...
    Brother_B's Avatar
    Brother_B is offline Cadillac Owners Fanatic
    Automobile(s): 1969 Coupe DeVille, 1972 Sedan DeVille
    Jan 2007
    Neptune Beach, FL
    44
    159
    From the troubleshooting guide in my manual:
    Malfunction: Inoperative (No Engagement)
    Component: Oil Filler and Pickup Tube: (1) Pick-up tube out of position, (2) o-ring cut or missing at case, (3) wrong strainer assembly, (4) strainer contaminated - restricted
    Component: Pressure Regulator Valve: (1) Valve stuck
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Describe how you are checking the transmission fluid.
    Apr 2007
    38
    HI,
    I have been checking transmission fluid as the manual says. Engine on, shift lever in park position and oil warm. Did it even more than one time and should be the right way but.....still problems...
    Brother_B's Avatar
    Jan 2007
    Neptune Beach, FL
    44
    159
    And also shift into all of the gears, Drive, Driver Left, Drive Right, Reverse before checking.
    Feb 2005
    Southern NJ
    54
    2,096
    Quote Originally Posted by lucaitaly View Post
    HI,
    Sorry to say we can rule that one out.
    Fabritory is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Mar 2007
    6
    i bought a 70 coupe deville with a transmission problem so i got it home tried to drive it but first gear was really slow only moving when i rev the shit out the motor so i went under the car and found a vacuum line riped off and a connector disconnected i connected the vacuum line and connector now the transmission is fine but a heavy vibration happens when it shifts i was wondering if anyone else has experience with this type of problem
    z06bigbird is offline Cadillac Owners Connoisseur
    Automobile(s): Sedan de Ville, CTS
    Mar 2007
    San Antonio, Tx
    4,769
    Seals are dried up. Add a brand name trans additive.
    If that does not work, add a can of STP oil (90 wt??) That helps trannies that do not shift.
  13. Remove Advertisements
