Oil change on my 72 500 - 10W30?
Results 1 to 4 of 4
500, 472, 425, 368 Discussion, Oil change on my 72 500 - 10W30? in Cadillac Engine Discussion; I'm about to do an oil change on my 72 eldo with the 500. Wondering what weight oil I should ...
    n3rdcore's Avatar
    n3rdcore is offline Cadillac Owners Member
    Mar 2004
    SoCal (Coachella Valley)
    33
    I'm about to do an oil change on my 72 eldo with the 500. Wondering what weight oil I should get. The manual is recommending like 4 different weights so thought i'd ask here. On my Oldsmobile Delta 88 455 I used 10w30, but now I live in the desert where it gets up to 120 F in the summer, so not sure if there is some other weight i should use, and I'm far from an expert on this...Any suggestions? Thanks!
    tripleyellow78cad's Avatar
    tripleyellow78cad is offline Cadillac Owners Fanatic
    Mar 2004
    central california
    37
    127
    Re: Oil change on my 72 500 - 10W30?
    Quote Originally Posted by n3rdcore
    I live in bakersfield ca
    and it gets very hot here too in the summer sometimes 110 degrees
    and i use 10w30 in all of my cars 1978 cad 425 v-8 1990 gmc tbi350
    and it works well, also 10w40 or 30w should work too but i stay with 10w30 yearround .
    also i found out that synthetic oil's will eat the crap out of your rings , and all of your engine gaskets so stay away if you have an old engine that leaks a little oil
    or uses any oil , like my old cad!
    hope that helps :coolgleam
    n3rdcore's Avatar
    Mar 2004
    33
    cool thanks tripleyellow78cad. i think i will stick with the 10w30! Oil change time...
    Mar 2004
    central california
    37
    127
    ]you're welcome , happy to help
  7. Remove Advertisements
