1988 Brougham (307) carb issue - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
5.0 and 5.7 Discussion, 1988 Brougham (307) carb issue in Cadillac Engine Discussion; Originally Posted by joe_padavano The fan motor is very easy to test. There is a power wire with a rubber ...
  1. #16
    XL2007 is offline Cadillac Owners Member
    Automobile(s): 1988 Brougham (307 CFI)
    Nov 2006
    Nowheres.
    10
    Re: 1988 Brougham (307) carb issue
    Quote Originally Posted by joe_padavano View Post
    The fan motor is very easy to test. There is a power wire with a rubber cover on the connector and a ground strap or wire. Be sure the ground strap is in place and making contact. Now pull the power wire off and connect a +12V feed directly from the batter positive terminal to the motor terminal. If the motor works, the problem is in the control wiring. If the motor doesn't turn, replace the motor.
    I'll go about testing the fan motor when I have more time. On the other hand, I have a suspicion that it might be a fuse.
  2. #17
    m.nguyen66 is offline Cadillac Owners Member
    Automobile(s): 1988 cadillac brougham
    Feb 2012
    3
    i personally would go through your spark splugs and make sure the gap is right too make sure all of your cylinders are working
  3. Remove Advertisements
