headers for my 1990 brougham 5.7
Results 1 to 9 of 9
5.0 and 5.7 Discussion, headers for my 1990 brougham 5.7 in Cadillac Engine Discussion; is there any headers made for broughams or is there some made for a truck that would fit. also would ...
    pcm
    pcm is offline Cadillac Owners Fanatic
    Automobile(s): 1990 brougham
    Oct 2005
    okmulgee
    156
    is there any headers made for broughams or is there some made for a truck that would fit. also would installing roller rockers free up any hp or be a waste of time. I have to change the valve seals any way so it wouldn't be any more work than I have to do to start with. but would it be worth a try.
    90Brougham350's Avatar
    90Brougham350 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 FWB, 93 SDV, 94 FWB (sold), 90 Brougham (sold)
    Jan 2005
    River Falls, WI
    31
    3,730
    Re: headers for my 1990 brougham 5.7
    Yup, changing the rockers will help a little, because the 350 desparately wants more cam than the stocker. I would guess 10-15 ponies. 'Course the best thing to do would be a cam swap. Without changing the heads, a cam swap on a 350 TBI can get you easily 60 ft. lbs.
    Regarding headers, I think any Impala SS headers will work. Fullsize GM 74-9x headers should work as well. Clear Automotive Image sells some Tri-Y headers for non-LT1 350's.
    pcm
    Oct 2005
    okmulgee
    156
    would I have to pull the motor to change the cam. and how much more gas would it use with a mild cam swap.oh! my cad has over 300,000 miles so I don't want to put more strain on the motor. but it is still strong and smooth running. the owners before me must have taken good care of it.
    i
    Jan 2005
    River Falls, WI
    31
    3,730
    Well, with 300,000 miles, the engine could use a few new parts. How is your compression? If the compression is good, then it would be worth it. Adding a cam would mean a new timing chain and gears, never a bad idea, especially if the stockers have 300,000 miles on them. Depending on what cam you chose, mileage will vary. Of course, with more power comes the desire to mash the fun pedal more too, so gas mileage will drop.
    Destroyer is offline Awaiting Email Confirmation
    Automobile(s): '67 Cutlass,'92 Z28, '12 Crosstour, '12 Cube,00 GMC 4500
    Oct 2003
    Florida
    45
    6,165
    3rd gen Camaro headers will fit the Fleetwood. Thing is, once you start with headers and cam then exhaust....................you will want to "floor it" more and will blow your motor. I suggest a 383 stroker crate motor with a carb personally. Priced right around $3k or so complete (less accessories) it would be the best bang for the buck. I'm too lazy to post the link but some guy sells 425hp Vortec stoker 383's on ebay and has good feedback for right around $3k. You will need to do a performance build on the tranny to handle it unless you take it easy off the line.
    Jan 2005
    River Falls, WI
    31
    3,730
    Are they shorties or long-tubes?
    Oct 2003
    Florida
    45
    6,165
    Quote Originally Posted by 90Brougham350 View Post
    shorties
    Jan 2005
    River Falls, WI
    31
    3,730
    I'd be averse to going with the shorties, because of the stock torquer cam. If the goal was high-end horsepower, I'd be all over the shorties.
    boatman is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Apr 2007
    19
    is there any testing on the shorties for performance gains? I would check the data sheets before changing over.
  12. Remove Advertisements
