missing, LT1
Results 1 to 12 of 12
5.0 and 5.7 Discussion, missing, LT1 in Cadillac Engine Discussion; Hi i just changed my waterpump, plugs, pcv, fuel filter, oil, egr valve and u joints. Now the car misfires ...
    Hammondsix's Avatar
    Hammondsix is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac Fleetwood 94
    Oct 2006
    121
    missing, LT1
    Now the car misfires on one cylinder on the passenger side, its intermittent. Im thinking that it is only a wire since its only on one cylinder, but my fear is that it could be the opti.
    What do you guys think?
    thanks alot
    94 Fleetwood, w 124k miles and full service history
    79caddy1's Avatar
    79caddy1 is offline Cadillac Owners Member
    Jul 2006
    PGH, Pa.
    67
    Re: missing, LT1
    Did this start doing it when you were done doing that work?....or is this why you changed the plugs?
    mine was doing that, due to a bad plug wire. Although, I changed the plugs too, after I figured it out.....
    BCs71's Avatar
    BCs71 is offline Cadillac Owners Enthusiast
    Automobile(s): 1994 Cadillac Fleetwood Brougham (some show and some go!)
    Oct 2003
    Chicagoland
    607
    Re: missing, LT1
    I'd definitely guess a wire. The looms that hold the wires underneath the exhaust manfolds are sharp and metallic. Perfect place for arcing.
    But you just changed the plugs? Gap is correct? What brand (some are cheap, stock Delcos are NOT cheap)??? Did you perhaps crack a plug during installation by accident? Maybe crossed plug wires accidentally?
    I'd double check a few of the above things.
    If you get a sray bottle of water and spritz the wires at nighttime you may be able to see some arcing if wire is frayed....
    79caddy1's Avatar
    Jul 2006
    PGH, Pa.
    67
    Re: missing, LT1
    Your right, I didn't think of a crossed wire during plug install....
    And yes, I bought cheapie plugs once....Only Once!
    Hammondsix's Avatar
    Oct 2006
    121
    Re: missing, LT1
    figured it out, i cracked one of the plugs. i doesnt run smoother with the new (bosch) plugs though...
    BCs71's Avatar
    Oct 2003
    Chicagoland
    607
    Re: missing, LT1
    Quote Originally Posted by Hammondsix View Post
    I would skip the Bosch and go with stock AC Delcos that came with the car. They hurt the pocketbook at $5 each but are worth it. Good for about 100K miles of driving and really are the best plug for stock LT1 vehicles (i.e., no NOS or superchargers).
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,533
    Re: missing, LT1
    Dual Platiunum Autolights are also worthy, but that is it. They AC Delco and the Autolights are very similar in construction and materials.
    RobDeville is offline Cadillac Owners Member
    Nov 2006
    54
    Re: missing, LT1
    Has anyone heard how hammond has made out?
    kevinf is offline Cadillac Owners Member
    Automobile(s): 96 FWB
    Sep 2006
    Chicago, IL
    33
    Re: missing, LT1
    I would guess it's arcing as well. Let the car idle with the hood up, if you hear a "clicking" that's probably it. You might even be able to see the arc jump.
    bigbluebrougham's Avatar
    bigbluebrougham is offline Cadillac Owners Fanatic
    Automobile(s): 1995 Cadillac Fleetwood Brougham
    Nov 2006
    South Dakota
    36
    118
    Re: missing, LT1
    Mine runs great with the Bosch ones. At least for now... I replaced my wires with lifetime belden wires from NAPA at the same time too.
    Hammondsix's Avatar
    Oct 2006
    121
    Re: missing, LT1
    The car runs ok with the cheapo bosch plugs, but not better than before. i guess the old ones didnt need changed.
    thanks
    Gwokable is offline Cadillac Owners Fanatic
    Automobile(s): 1988 Cadillac Fleetwood Brougham
    Dec 2006
    Chicago.
    146
    Re: missing, LT1
    My reccomendation: Ac Delco Rapidfires
    I'v installed them into a number of cars from different manufacturers and they always result into a respectable performance boost.
    Return the Bosch and tell them they actually reduced your HP.
  15. Remove Advertisements
