exhaust bolts
Results 1 to 10 of 10
5.0 and 5.7 Discussion, exhaust bolts in Cadillac Engine Discussion; Ok.... Which exhaust bolt are the best(strongest) replacement for my existing ones I have a 94 fleetwood with 124k miles. ...
    Hammondsix's Avatar
    Hammondsix is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac Fleetwood 94
    Oct 2006
    121
    exhaust bolts
    Ok....
    Here is what ive done to it.
    Transmission oil and filter
    Engine oil and filter
    plugs on the right side (waiting with the plugs on the other side untill i need to change the exhaust bolts)
    checked front bearings
    greased front end
    diff oil
    Fuel filter
    airfilter
    What else do i need to do?
    Hammondsix's Avatar
    Oct 2006
    121
    Re: exhaust bolts
    I guess this forum is more about chrome, paint and wheels than mechanical stuff...
    Im a little dissapointed to be honest. This is the second time i have a mechanical question that nobody can respond to.
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,531
    Re: exhaust bolts
    Honestly, this is the wrong forum for engine tech for the LT1, it is far better supported at impalassforum.com
    Don't dis the forum if you are coming for free help and don't get what you want in a few hours. Not everyone can get on her every hour of every day. Sorry to dissappoint you.
    Did you go to GM and order the new bolts? Grade 8 is as hard and tough as they come. Hence no answers. GM HAD issues with them breaking. eBay is a common place to find GM bolts too.
    BCs71's Avatar
    BCs71 is offline Cadillac Owners Enthusiast
    Automobile(s): 1994 Cadillac Fleetwood Brougham (some show and some go!)
    Oct 2003
    Chicagoland
    607
    Re: exhaust bolts
    Yep, I check in once a day except on the weekends most of the time. So be patient and I'm sure someone will come along and pitch in.
    I used grade 8 bolts (right from the bins in the hardware store, I just took old crappy grade 5 bolts in with me and measured them up for length comparison).
    GM also makes a direct replacement kit (pretty sure theirs are grade 8 also) that includes all new bolts of exact length, spacers, studs, nuts, etc. This was made and packaged together since so many LT1 vehicles with iron heads (B and D bodies) kept having broken bolts. Sorry, I don't know the part number.
    But Dal will definitely know the number if you give him a call or email him (have patience getting ahold of him) -- he has an encyclopedia of GM parts info and numbers in his brain and supplies GM parts cheaper than anyone else in the country.
    phone: 877-448-5451
    email: lockitup "at" bright.net
    I guess that depends on what your goals are with the car? Are you interested in performance mods or just general maintenance for now?
    As for maintenance, I didn't see a new PCV valve on your list. I would also consider new spark plug wires if still original, as well as oxygen (o2) sensors.
    Also consider disabling the AIR pump if it hasn't been already. It can introduce water (condensation, technically) into your air intake -- it will coat the MAF and give false readings, In worst case situations the water can even get into the engine. On your car you can simply unplug the pump at the wiring connector and then plug off the hose that runs into the airbox.
    Speaking of coating the MAF, it should be routinely cleaned anyway (carefully, the little wires inside are delicate) with electrical parts spray cleaner and a Q-tip. May also be a good idea to clean out the throttle body with TB cleaner spray.
    You can even consider the old Seafoam treatment through the brake booster vacuum hose if you think that you have carbon build-up (likely with your mileage). It's recommended that you change plugs AFTER this treatment, though.
    96Fleetwood's Avatar
    96Fleetwood is offline Auto Enthusiast
    Automobile(s): 1992 Eldorado Touring
    Jul 2005
    Naples, FL
    37
    3,688
    Re: exhaust bolts
    I second the grade 8 bolts. Check the gaskets too, you don't want one to blow and then have to do the whole process over again.
    2015 Audi Q7 3.0T S-line - my DD
    2013 BMW Alpina B7 - wife's DD
    2002 Pontiac Trans AM WS6 Convertible Collectors Edition
    1992 Cadillac Eldorado Touring Coupe
    Hammondsix's Avatar
    Oct 2006
    121
    Re: exhaust bolts
    Thanks alot.
    BTW that first message was written before my morning coffe, hence the cranky tone.
    sorry...
    ocjmakaveli's Avatar
    ocjmakaveli is offline Cadillac Owners Enthusiast
    Sep 2004
    illinois
    927
    Re: exhaust bolts
    Just go to any hardware store with one exhaust bolt and get grade 8 bolts.
    Sometimes theres a guy that sells the complete set on ebay but hes not selling any currently.
    I believe they are 3/8-16 and 1-1/2" long but some of them are 2" long if I remember correctly. Just try and replace them with a similar length.
    I recommend heating them before removal so they don't break.
    If you replace the gaskets use the napa gaskets because htey are made of metal. The autozone gaskets are flimsy plastic crap. The napa gaskets are more oem like.
    ShadowLvr400's Avatar
    ShadowLvr400 is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Fleetwood
    Oct 2003
    Central Florida
    34
    2,536
    Re: exhaust bolts
    Blar, don't be mean. It's too early in the day for grumpiness. And I've been busy, haven't been patrolling the forums as much. Grade 8's are the way to go. As for the gaskets, I don't have advice. I've got to live with some snapped off boltsmyself, at least until I do a teardown.
    GEORGE J UHLER is offline Cadillac Owners Member
    Aug 2006
    24
    Re: exhaust bolts
    If your really serious. With a 125 thou on the original motor it could be time to check the timing chain and gears for wear and looseness. Any slack at all on the timing chain would indicated the need for a replacement.
    When putting it back together it would be a good time too for replacing the Opti-spark distributor cap.
    Hammondsix's Avatar
    Oct 2006
    121
    Re: exhaust bolts
    so it looks like i have my work cut out for me.
    1, exhaust bolts
    2, egr valve,
    3 clean MAF
    4, left side plugs
    5 Timingchain
    thats a whole weekends worth of work...
    Thanks guys!
  13. Remove Advertisements
