1989 Brougham check engine light? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Like Tree1Likes
5.0 and 5.7 Discussion, 1989 Brougham check engine light? in Cadillac Engine Discussion; Originally Posted by joe_padavano Rather than randomly disconnecting stuff, why not read the stored codes and make an intelligent diagnosis? ...
  1. #16
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: 1989 Brougham check engine light?
    Quote Originally Posted by joe_padavano View Post
    Rather than randomly disconnecting stuff, why not read the stored codes and make an intelligent diagnosis? Jumper the two top RH terminals of the ALDL connector together and the check engine light will flash with the trouble codes (assuming you haven't removed the bulb as others have suggested).
    Who's doing anything randomly? Re-read the thread. He got a code 31. Canistor purge valves shorting was a known issue in that era.
  2. #17
    joe_padavano is offline Cadillac Owners Member
    Automobile(s): 93 Allante
    Mar 2006
    Northern Virginia
    78
    Quote Originally Posted by The Ape Man View Post
    DOH! I missed that. Sorry.
  3. #18
    ReagansRollsRoyce is offline Cadillac Owners Fanatic
    Automobile(s): 1987 Cadillac Fleetwood Brougham
    Aug 2004
    Connecticut
    183
    Not positive on a 31 meaning but... as for the flashes
    On my '87 It always flashes code 12 first three times to show the system is working...flash *pause* flash-flash...repeat 2 more times
    a 31 would come out like so flash-flash-flash *pause* flash....this would repeat 2 more times and as long as there were no other codes it would then do 12 again.
    when it's a higher number than one, the flashes are going to be really close together...so the pause shows you where the first digit stops and the second begins
  5. #19
    Aug 2004
    Connecticut
    183
    Off and warmer trick does not work on 307 cars. Riding around with the engine lamp on is a good way to land up on the back of a hook. It would be different if the problem were known and was something that could let the car fly without going into open loop.
    Yeah...my old mechanic taught me to use a paper clip to read them out of the data port under the ashtray. the two top right holes.
  6. Remove Advertisements
