Technical help 307
Results 1 to 4 of 4
5.0 and 5.7 Discussion, Technical help 307 in Cadillac Engine Discussion; I just bought a 1987 fleetwood with a 307. Engine was overheated. I have a 5.1 that came out of ...
    snukie75 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2006
    Technical help 307
    I just bought a 1987 fleetwood with a 307. Engine was overheated. I have a 5.1 that came out of a 1980 olds. Will this engine work in my caddy if so can I swap the heads and intake from the 307 to the 5.1. help
    ShadowLvr400's Avatar
    ShadowLvr400 is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Fleetwood
    Oct 2003
    Central Florida
    34
    2,536
    Re: Technical help 307
    A 5.1?? That'd be what, a 318? No, that's 5.2 Mopar... I need more details on these 2 motors.
    As for an engine swap, the keys are tranny bolt up, and computer. The cars are old enough to be kinda dumb, but not totally comp free.
    Sep 2006
    I am sorry the engine out of the olds is a 301 and the engine out of the cadillac is a 307.
    joe_padavano is offline Cadillac Owners Member
    Automobile(s): 93 Allante
    Mar 2006
    Northern Virginia
    78
    Quote Originally Posted by snukie75 View Post
    Are you sure it's a 301? That would be a Pontiac-built motor and the only thing it has in common with the Olds-built 307 motor in your Caddy is the bellhousing bolt pattern and the distributor cap. More importantly, Olds didn't use the Pontiac 301 in 1980, so either that's not the original motor or it's not a 301. The only V8s that were installed in Oldsmobile cars in 1980 were either Olds-built motors (260 or 350) or Chevy small blocks (265 or 305). What type of Olds is that motor out of and what's the fifth character of the VIN?
    By the way, 301 cu in = 4.9 liters
  7. Remove Advertisements
