Replacing front crank oil seal on LT1
Results 1 to 4 of 4
5.0 and 5.7 Discussion, Replacing front crank oil seal on LT1 in Cadillac Engine Discussion; Hello chaps. Sorted the oil change on the '94 Fleetwood yesterday. Got oil coming out the front crank seal on ...
    425 Dual Quad's Avatar
    425 Dual Quad is offline Cadillac Owners Fanatic
    Automobile(s): '94, '93 & '76 FWBs. '77 '79 & '73 CDVs, '65 Drop, '62 CDV
    May 2004
    Ireland
    55
    406
    QuestionReplacing front crank oil seal on LT1
    Hello chaps.
    Sorted the oil change on the '94 Fleetwood yesterday. Got oil coming out the front crank seal on the LT1 motor. How do I replace the seal. Looks like getting the harmonic balancer off will be no fun.
    Is there a tech tip/ any ideas?
    Thanks
    Nick
    BCs71's Avatar
    BCs71 is offline Cadillac Owners Enthusiast
    Automobile(s): 1994 Cadillac Fleetwood Brougham (some show and some go!)
    Oct 2003
    Chicagoland
    607
    Re: Replacing front crank oil seal on LT1
    I'd replace the seal for the water pump drive as well while you are at it:
    http://www.impalaclub.com/naisso/for...TOPIC_ID=30984
    In fact, it may be leaking from there or the opti drive as well and dripping down the front of the timing cover, giving you the impression the bottom seal (crank) is the leaker.
    These links below are for a Camaro, but the procedure is basically the same for balancer & hub removal. The hub is tricky, I've done it a bunch of times and it never seems to go completely smooth. You need a puller tool along with varying lengths of bolts that the puller will "push" against after the crank snout bolt is removed. The bolts need to be slightly smaller in diameter than the crank bolt so that they do not thread in, yet still thick enough so they are tough and do not bend when the puller "pushes" against them.
    http://shbox.com/ci/cam_removal.html
    http://shbox.com/ci/cam_install.html
    Feel free to PM or email me if you have questions that are specific, I only check in here once a day, but not on the weekends.
    May 2004
    Ireland
    55
    406
    Thumbs upRe: Replacing front crank oil seal on LT1
    Thanks BCS71,
    Replaced the seal. It all went well and no leaks so far. I think it was the crank seal and not the other one.
    Many thanks for all your assistance.
    regards
    Nick Strattta
    BCs71's Avatar
    Oct 2003
    Chicagoland
    607
    Great to hear! I hope the crank hub removal and reinstallation went smoothly. That part always give me fits even though I know exactly what I am doing.
    Cheers,
    -BC
  7. Remove Advertisements
