1990 Brougham Running Rich
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
5.0 and 5.7 Discussion, 1990 Brougham Running Rich in Cadillac Engine Discussion; What Would Cause My 1990 Brougham To Run Rich? It Has A 5.7l Under The Hood. I Have Changed The ...
    PAGEJR is offline Cadillac Owners Member
    Mar 2006
    28
    What Would Cause My 1990 Brougham To Run Rich? It Has A 5.7l Under The Hood. I Have Changed The Coil And Performed A Full Tune-up. I Tested The Volts Form The Battery And The Alternator. The Battery Is At 13.9v. I Read That It Should Be Around 14.2. Would This Make The Car Run Rich? Also I Am Experiencing The Shudder Every Once In Awile And The Stalling In Reverse That Dopestar Was Experiencing. When I Did The Tune-up I Did Not Gap The Plugs. I Am Assuming This Would Not Cause That. Thanks In Advance For The Info.
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,533
    Re: 1990 Brougham Running Rich
    Are you getting any check engine light codes?
    Mar 2006
    28
    No There Are No Codes. I Was Thinking About Changing The Tcc Solenoid. I Know It Idles Weird When Its In Gear. But It Seems To Run Rich All The Time.
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    50
    7,533
    Canister Purge turns on when you are in gear, just off idle (on gas even the slightest bit), but off at idle.
    Check that it is connected up properly and not damaged, or the solenoid for it isn't damaged.
    90Brougham350's Avatar
    90Brougham350 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 FWB, 93 SDV, 94 FWB (sold), 90 Brougham (sold)
    Jan 2005
    River Falls, WI
    32
    3,730
    Well, pull a few of the plugs and let's have a look at them. There's a few different things that would be causing the engine to run rich, but most would throw trouble codes. How is your timing? Check that, it'll make a world of difference if it's off even a few degrees. The alternator is just getting old, don't worry about it. When it drops into the 12's, then it's time to worry. Not gapping the plugs is an easy mistake that rarely has repurcussions, it wouldn't be anything like what you're experiencing. But pull a few plugs, and check them. There's a lot of guides with pictures on the internet, this one is decent.
    http://www.dansmc.com/Spark_Plugs/Sp...s_catalog.html
    Good luck!
    Brian
    Mar 2006
    28
    Thanks, I Will Try That Tonite And Post The Results. Im Also Gonna Put A New Converter On. I Gutted The Old One Because It Was Clogged Up. Tnaks For The Advice!!
    Mar 2006
    28
    I Pulled The Plugs, They Were Fine. Also Changed The Fuel Filter And Cat. It Ran Okay For A While, Then It Started Back. Could The Tank Be Dirty. When I Changed The Fuel Filter, Alot Of Dirty Gas Came Out. I Mean Gritty. I Might Pull The Fuel Filter Off Again To See If Its Dirty.
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    50
    7,533
    Why do you think it is running rich? The plugs tell the story, if rich, they will be black, and even wet if really bad.
    What did they look like?
    Jan 2005
    River Falls, WI
    32
    3,730
    Check all the vacuum hoses on the engine, if they're even at all worn, replace them. You might have a leak somewhere.
    Brian
    Mar 2006
    28
    I Think Its Running Rich Because Of The Way The Exhaust Smells. Its A Real Strong Smell, Not Like Gas, But A Real Bad Exhaust Smell. I Know When I Changed The Cat It Helped A Little Bit. I Checked The Hoses And I Did Not Find Anything. I Do Hear A Hissing Sound When The Car Is Started. I Spent An Hour Looking To See If Any Hoses Were Damaged. I Found Nothing. Could The Hesitation Be A Converter Problem. It Idles Fine When Its In Park.
    Jan 2005
    River Falls, WI
    32
    3,730
    Hesitation is usually a sign of retarded timing, but not always. How is the timing?
    Brian
    Mar 2006
    28
    Im Not Sure How The Timing Is. Can I Check That From Home? Or Do I Need A Timing Light?
    Jan 2005
    River Falls, WI
    32
    3,730
    Nah, you'll need a timing light. Good tool to have, but if you don't want to pick one up, most parts stores will let you rent one. If you want a little extra pep, I have the timing on my 90 advanced 10 degrees and I run at least 91 octane. The light and mid throttle response is much snapier.
    Brian
  16. #14
    Mar 2006
    28
    Okay I Will Try That. Is It A Hard Process To Do? I Was Gonna Get The Motor And Trans Rebuilt In The Fall. I Just Dont Wanna Make Things Worse Until Then.
  17. #15
    Jan 2005
    River Falls, WI
    32
    3,730
    Checking the timing is very easy to do, you start with hooking the timing light up. 3 cables, one you hook to the battery's +, the other to the battery's - then the one with the odd-looking clamp goes around the #1 cylinder's spark plug wire. Look at the large wiring bundle that runs infront of the blower motor to behind the distributor. There should be a tan and black wire with a connect that sticks out of the wire shroud. Disconnect this connection. Now start the car, and aim the timing light down onto the balancer. You'll see the marks lining up with whereever your timing is currently. If it's retarded before 0, that's a problem. A distributor wrench (at any auto parts store) allows you to loosen the distributor and turn it by hand while the engine is running, thus retarding or advancing the timing. Feel free to ask questions, that's what we're here for. The guys at the parts store can help you out a lot too! Good luck!
    Brian
  18. Remove Advertisements
