Carb problems: Rochester Quadrajet
Results 1 to 13 of 13
5.0 and 5.7 Discussion, Carb problems: Rochester Quadrajet in Cadillac Engine Discussion; i have an 87 fleetwood brougham and have been dealing with carb problems for months. it actually left me stranded ...
    BEOWOLF's Avatar
    BEOWOLF is offline Cadillac Owners Member
    Dec 2004
    Dallas, Texas
    42
    10
    i have an 87 fleetwood brougham and have been dealing with carb problems for months. it actually left me stranded and i had to park it until i could get the money up to fix it. the carb was dumping too much fuel. i was quoted $600 for a refurbished carb, i thought that was too high, so i had mine rebuilt, by my father in law...but it has still been hell trying to get it tuned just right. anyone else had trouble with these carbs???
    suggestions on the best permanent fix?
    BluEyes's Avatar
    BluEyes is offline Cadillac Owners Enthusiast
    Automobile(s): 1970 Sedan deVille hardtop
    Feb 2005
    595
    Re: Carb problems: Rochester Quadrajet
    Get the Doug Roe book on Rochester Carburetors. There's also some good info out on the net on setting up and tuning Q-jets. Do a search in the 368/472/500 forum, I posted some info there about Q-jets awhile ago.
    What problems are you having with the carb specifically?
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,531
    Dumping fuel, look to the float, these commonly go bad when old. Is there a fuel filter installed in the housing? If some dirt came by and got lodged in the needle/seat? Is the M/C solenoid clicking when it is running? Is the ECM working?
    Then clean it, gumout is preffered, be careful with Walmart brand carb cleaner, although cheap, it strips the gold coatings off the carb. Very harsh. Clean all orifices and passages when it is on the car. Often that is all that is needed.
    Q-Jets are not hard to rebuild. Attention to detail on them is key. Clean clean clean. If there is dirt in a passage, it will screw up the air metering, but not enough to DUMP fuel.
    I have some good mods for q-jets on one of the forums (probably here), but do not attempt until the carb is running perfect.
    that book from Doug Roe is aweseome. Must have.
    iNdy.j's Avatar
    iNdy.j is offline Cadillac Owners Member
    Feb 2006
    Minnesota
    40
    31
    If the fuel filter needs a change you smell gas? Does a dirty fuel filter affect performace?
    johndfw's Avatar
    johndfw is offline Cadillac Owners Fanatic
    Sep 2005
    Arlington Texas
    52
    201
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    50
    7,531
    It will smell if there is a leak, that is bad, be very careful. Look for the leak and fix it.
    A plugged filter will cause the engine to be lean, killing off power and raising emissions.
    johndfw's Avatar
    Sep 2005
    Arlington Texas
    52
    201
    Night Wolf's Avatar
    Night Wolf is offline Cadillac Owners 10000+ Posts
    Automobile(s): Unicycle
    Mar 2003
    Where I park it
    11,009
    You can buy a rebuilt carb from various companies (forgot the name) for about $350. That is your best bet. A couple family members did that as well as Dope, much better then trying to mess with yours if you are not familer with it.
    fullserviceman is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Fleetwood Brougham
    Apr 2005
    Albany, NY
    37
    244
    rockauto.com has em for $400 ish and I think advance auto has them for about $350. I always had trouble with the floats sticking and dumping fuel so much that it was in the oil. Doesn't take much dirt to hang those up.
    BEOWOLF's Avatar
    Dec 2004
    Dallas, Texas
    42
    10
    thanks for all the help peoples. this should set me straight. i have been driving it around now...but every once in a while...after it gets up to operating temp...it will just die on me, and make it real hard to restart...once i do, it runs like ass unless i let it sit for a while. then we do that tango all over again. i will fix this damn it...at least she's rollin'.
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    50
    7,531
    Make sure you are not fighting the EVAP emissions system allowing fuel in the bowl vent or the purge line.
    vanaisa's Avatar
    vanaisa is offline Cadillac Owners Enthusiast
    Automobile(s): `65 DeVille Convertible´67 Eldorado,´02 DHS
    Apr 2003
    Tallinn, Estonia
    48
    517
    I bought few carbs from http://recarbco.com/ - remanufactured and adjusted to factory specs. And prices are reasonable too (67 Eldo - $200, 69 Deville - $240 etc)
    johndfw's Avatar
    Sep 2005
    Arlington Texas
    52
    201
    Hey man
    Is the car doing any better?
  16. Remove Advertisements
