1993 fleetwood misses while stopped at light
Results 1 to 8 of 8
5.0 and 5.7 Discussion, 1993 fleetwood misses while stopped at light in Cadillac Engine Discussion; 93 fleetwood just put cap and rotor and plugs and wires fuel filter air filter breather filter pcv valve ..........flushed ...
    bigmikelilmike is offline Cadillac Owners Member
    Automobile(s): 93 fleetwood 76 coup
    Sep 2004
    22
    93 fleetwood missing while sitting at red light
    93 fleetwood just put cap and rotor and plugs and wires fuel filter air filter breather filter pcv valve ..........flushed radiator just doing stuff it needed but it still misses and idle drops low for split second and seems fine while driving but stopped it misses any ideas i got almost 94000 miles on the fleetwood thanks for any advice ...big mike
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,533
    Re: 93 fleetwood missing while sitting at red light
    Did you gap the plugs out of the box or trust that they were ok? 90% of the time I have found my idle misses are too wide spark plug gap or too narrow. Both will cause idle miss. For Turbocharging, I ran a slightly narrower gap and had to put up with the miss, as under boost, the boosted A/F mix will try to snuff out the spark, so a narrower gap typically helps.
    I am guessing being it is a L05, it should be 0.050" gap. Not 0.060" like the BOP engines typically were. Chevy always had to deal with a narrower gap for some reason. Pontiac was fond of 0.060", and Olds even flirted with 0.080" for a while on some.
    Sep 2004
    22
    Re: 1993 fleetwood misses while stopped at light
    i trusted them out of the box i will check in to that thanks for advice anything else to check ,,,,..........
    JTraik is offline Cadillac Owners Enthusiast
    Automobile(s): Too many...
    Mar 2004
    30
    857
    Quote Originally Posted by bigmikelilmike
    I did too... same engine as well. I had a miss i tracked it down to the #8, removed my bosch platinum and the the tab was smushed right down on the electrode!
    I noticed you did some coolant work. When i changed the tstat on my L05 there is a ground wire that goes on one of the water outlet hold-down bolts. I was drivin around with that ground off (didnt know it) my friggin airbag light was on... wiper functions didnt work... and at a stop the engine would run all jumpy and weird. Found the disconnected ground and presto! Just somethin to watch out for!
    Sep 2004
    22
    thanks for advice guys im gonna check it out tomm..........
    Sep 2004
    22
    well guys i thought i migt have a vacum leak but havent found one replaced the iac and the egr valve which both had a bad carbon build up and looked like they needed replaced anyways the egr seemed to help some accelrates better but its still missing or surging while stopped ...any ideas guys thanks
    Tailfin's Avatar
    Tailfin is offline Cadillac Owners Enthusiast
    Automobile(s): 1996 Deville Concours
    Jan 2004
    New York (verified rust state)
    35
    803
    Did you check the ignition & pickup coils? Might want to stick a multimeter on the battery while it's running too, and make sure it's 14+ volts. If not, the alternator might be going and taxing the electrical system.
    Sep 2004
    22
    didnt check coils or battery alt but will look into it thanks ...
  11. Remove Advertisements
