A.I.R. pump removal problems
Results 1 to 4 of 4
5.0 and 5.7 Discussion, A.I.R. pump removal problems in Cadillac Engine Discussion; well removal was going great until i got to unscrewing the nuts at the heads. 3 of them came off ...
    pimpin88's Avatar
    pimpin88 is offline Cadillac Owners Connoisseur
    Automobile(s): 01 STS, 92 Roadmaster, 01 SLS-sold, 88 Brougham-crushed
    Nov 2004
    northeast ohio
    28
    1,392
    well removal was going great until i got to unscrewing the nuts at the heads. 3 of them came off ok, but when i went to do the fourth one (which also happened to be the rearmost one) before i even put the wrench on it i knew something was wrong. so i touched the nut and found out the it was rusted away from the threads.
    so now, the threads are still in the hole without the nut, and i wont be able to put a plug in there.
    any suggestions, and how big of a problem is this?
    90Brougham350's Avatar
    90Brougham350 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 FWB, 93 SDV, 94 FWB (sold), 90 Brougham (sold)
    Jan 2005
    River Falls, WI
    32
    3,730
    Re: A.I.R. pump removal problems
    Have you ever used an Easy-Out? It's a type of left-handed drill bit that grips as it turns counter-clockwise. The only problem I can see is having anywhere near enough room to get in there first with a drill, but you could just stick the Easy-Out in the hole and turn it with a wrench! Try putting some heat from a propane or Mapp cylinder on it and some liquid wrench. Good luck!
    Brian
    pimpin88's Avatar
    Nov 2004
    northeast ohio
    28
    1,392
    yea, i've used an easy-out before. its just that there is no way that a drill would fit in there. i'll try using a wrench. hopefully it'll work. thanks
    andrew
    Jan 2005
    River Falls, WI
    32
    3,730
    I suppose if you're having too much difficulty you could remove the exhaust manifold completely to get at it, but then you run the risk of breaking off a manifold bolt, which would be far worse than the situation you're in now. Good luck!
    Brian
  7. Remove Advertisements
