Should rear main seal be replaced when transmission is out?
Results 1 to 4 of 4
5.0 and 5.7 Discussion, Should rear main seal be replaced when transmission is out? in Cadillac Engine Discussion; On my 94 FWB. I'm about to install a new tranny and although the seal doesn't appear to be leaking, ...
    atikovi is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Professional Chassis Raised Roof Presidential Limousine
    May 2003
    Suburban Washington DC
    400
    On my 94 FWB. I'm about to install a new tranny and although the seal doesn't appear to be leaking, the car has 110K miles. Do I need a special tool to install the seal like the manual says or can I improvise something?
    FrankieSixxxgun is offline Cadillac Owners Fanatic
    Automobile(s): 1987 Fleetwood Brougham
    Apr 2005
    Clearwater, FL
    34
    239
    Re: Should rear main seal be replaced when transmission is out?
    If it's not leaking, don't touch it! Putting a seal in without removing the crank rarely holds tight, so it's holding up, don't mess with it. Plus, you don't wanna drop the oil pan to do it anyway, it's a PITA.
    ocjmakaveli's Avatar
    ocjmakaveli is offline Cadillac Owners Enthusiast
    Sep 2004
    illinois
    927
    Quote Originally Posted by atikovi
    Trust me do it now or else you'll regret it in 10-15K later when you have to drop the tranny again just to replace this damn $5 seal.
    I don't remember if you have to remove the oil pan to replace it because i replaced my oil pan gasket anyway but its really easy to replace the main rear seal use the fel pro seal from autozone its really good and its only 2 screws remove them and the seal comes out then just reinstall the new seal Really easy hard part is removing the trans.
    It's a part with a high chance of failing and no real reason not to replace it. I'm sure its less than $10 at autozone and they have it in stock.
    Apr 2005
    Clearwater, FL
    34
    239
    Maybe I'm just used to Chevy motors, but if it don't leak, don't touch it is my motto.
  7. Remove Advertisements
