what to do? what to do?
Results 1 to 7 of 7
5.0 and 5.7 Discussion, what to do? what to do? in Cadillac Engine Discussion; i got a 93 fleetwood and wanna throw lt1 in and take out stock 350. is it worth the money, ...
    rivie'sfleet is offline Cadillac Owners Member
    Aug 2005
    chicago
    33
    10
    i got a 93 fleetwood and wanna throw lt1 in and take out stock 350. is it worth the money, or should i just tinker with the stock slo-poke and convert to port fuel injection. any advise is welcome.
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    Re: what to do? what to do?
    I have the same car and have done some research. I think the LT1 swap is pricey and complicated. The path I'm going to take is this.
    Keep the L05 engine. Do a factory Vortec head conversion and by 'factory' I mean from GM you can almost by a kit do do this. When you go to get the heads they're going to recommend an intake and a cam. All from GM. YOU CAN NOT USE THE L05 intake on the Vortec heads. SO that swap alone is going to get you somewhere in the range of 100HP or so. GM's claim is that the heads alone give you 50HP
    So now you have quite the sleeper. Check your build sheet for the differential gearing. If you car has the tow package then you'll have 3.73's in there. If you're telling me your car is slow that probably not the case. Grab yourself a Detroit Locker with a set of 3.55's or 3.73's and I'm thinking you'll be pretty happy
    Make sure the tranny's tight before all of this.
    Quote Originally Posted by rivie'sfleet
    Aug 2005
    chicago
    33
    10
    i'm not a tranny person at all. damn near retarded about the subject, if u ask me. how do i know how my tran is doing?
    90Brougham350's Avatar
    90Brougham350 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 FWB, 93 SDV, 94 FWB (sold), 90 Brougham (sold)
    Jan 2005
    River Falls, WI
    31
    3,730
    I have asked about upgrading an LO5 on Chevy High Performance's website. If you can't afford to do heads yet then the right cam will take care of business.
    "This is an excellent opportunity to put some beans into the 350. The version your Caddy has only develops an emasculated 175 horsepower. You really don't need to add more slip with a high stall converter, given the funky ways converters work, you won't see the difference with such a heavy car at the far end of such a gutless engine. You need some torque and ponies injected into the Cad. The route to happiness in this case is more cam, more cam just about anything with bigger lobes than a broomstick is more cam, some heads and if you want to go crazy headers and a cat back exhaust. With a little effort this motor will easily double the output and be smooth, tractable and smog legal.
    Depending on whether you live in California or a place that tests to California standards determines some of what you can do. A good cam choice would be a Crane 2030 P/N 104221, this is a hydraulic roller that slips right in it improves timing from what you have at 170/184 with less than .4 inch lift to 204/214 at .429/.452. This stick will add about 80 ft pounds of torque and about 60 horsepower. Then depending on California or not, a set of Vortec heads which require an intake change for bolt pattern will add an easy 40 ft pounds and a like amount of ponies. If in Calif. a set of Edlebrock Performer heads, while more expensive, add the same or a bit more power, use your stock TBI intake and are CARB/50 State legal. So we've moved this turkey from 175 to 275 horeses no sweat with an additional 120 ft pounds. A set of headers and a cat back exhaust could add another 20 to 30 ponies up toward the top end.
    Bogie"
    Brian
    Aug 2005
    chicago
    33
    10
    270 horses sounds great, actually. what am i looking at price wise? i'm in chicago, where testing isn't too strict around here. i think i can get away with a bit.
    Aug 2005
    chicago
    33
    10
    i also wanted to know if the 350 tbi was worth holding on to. it's got 150,000 miles on it. do you guys think its time to let her go and start fresh with an lt1?
    Jan 2005
    River Falls, WI
    31
    3,730
    If you can afford to upgrade to an LT-1 from a tired old L05, then you can afford to build a big block Caddy, maybe a 472!
    Brian
  10. Remove Advertisements
