Go Back   Cadillac Owners Group > Cadillac Engine Technical Discussion > 5.0 and 5.7
5.0 and 5.7 This forum is to discuss the newer, small block Cadillac engines.
Cadillac Forums: 93 FW engine problem
Old 02-08-05, 04:38 PM
miaryder05 miaryder05 is offline
View miaryder05's Photo Album
Casino Cash: $250
wuz up everyone im having engine problems with my engine. every time i start the car it has a rough start and when the car is on its start stutering. i have a felling its a fuel thing.... when you gas the car it hesitates and you leave your foot on the gas it makes a pop sound and then the car goes ... and the car doesnt stop doing that... im gonna change out the fuel filter to see it fixes the problem.... any advise would be greatly apriciated......
thanks , Ralph
  #2 (permalink)
Old 02-11-05, 05:52 PM
Casino Cash: $250
Re: 93 FW engine problem
anyone please????
  #3 (permalink)
Old 02-11-05, 06:42 PM
Vesicant's Avatar
Vesicant Vesicant is offline
It takes the caek.
Cadillac(s): 0
View Vesicant's Photo Album
Casino Cash: $6565
That pop is probably a backfire.
This could be a lot of things, some of which could be...
Dirty injectors, dirty/sticking throttle body plate, fuel delivery, mass airflow sensor, bad sparkplugs, fuel pressure regulator, even a dirty airfilter.
Are there any codes set (have them checked), service engine soon light on?
Is this the 5.0, 5.7 or LT1?
  #4 (permalink)
Old 02-11-05, 11:03 PM
Casino Cash: $250
i have a 350 5.7 no service engine soon light. i just rebuilt the engine a year ago and only put like 3500 miles on it. im gonna put it on a computer tomorrow to see if that pick up anything . whats confusing is that.it does it when ever it feeel like it. mostly when i start the car it starts boging out and when i drive it stalls alittle and has turned off on me a couple of times. thanks for the list of possible problems now i have something to let the mechanic know. again thanks alot.
  #5 (permalink)
Old 02-11-05, 11:07 PM
Casino Cash: $250
how do i check the codes ?? thanks
  #6 (permalink)
Old 02-11-05, 11:45 PM
Vesicant's Avatar
It takes the caek.
Cadillac(s): 0
Casino Cash: $6565
Have the mechanic also diagnose the idle air control valve, and egr. These could also attribute to your problem.
Checking the codes, you can do it on your vehicle by yourself:
First step to initiate it is to
Turn ignition "ON."
Depress the "OFF" and "WARMER" buttons on the Climate Control Center (CCC) simultaneously and hold until the segment check appears on the Instrument Panel Cluster (IPC).
Then follow this site to get the codes:
http://myweb.accessus.net/~090/dtcobd1.html#ide
  #7 (permalink)
Old 02-12-05, 01:06 AM
Casino Cash: $250
i just changed the air filter witch was really dirty and the breather at the bottom of the breather it had alittle oil and around the plastic on the out side where the plug hooks to... i replaced those car runs alittle better but still bogs out.... im gonna try the codes ill let you know what it was.. thanks
  #8 (permalink)
Old 02-12-05, 01:27 AM
Casino Cash: $250
tryed the codes just stays on -00 i held for like 5 min and left it alone and nothing..
  #9 (permalink)
Old 02-12-05, 01:56 AM
Keyth's Avatar
Keyth Keyth is offline
Cadillac(s): ETC
View Keyth's Photo Album
Casino Cash: $250
Hook a timing light up to each plug.. Same thing was happening to my '93 ETC and it was a coil that went out.. 19.99 at AutoZone... It has gone out on me twice in 234000 miles... Same coil the #1/4 Yours may be different.. There are no codes that occur when you lose a plug.. Don't believe me try taking a plug wire off.. The first time diagnosing it was a pain because the spark was just enough to trigger the timing light to go off...
My 2 Cents..
  #10 (permalink)
Old 02-12-05, 02:10 AM
Casino Cash: $250
im not really a mechanic i dont know nothing about a engine but how to change the oil and the basic stuff. im gonna take to a mechanic tomorrow and see what they tell me. one of my friends told me to twist alittle coil or something like that. i hope it something small. keyth thank for your advice.
Tags: ,
engine, problem
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
vacation travel
golf store
silver, gold, diamonds
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
