96 fleetwood pass key fault
Results 1 to 4 of 4
5.0 and 5.7 Discussion, 96 fleetwood pass key fault in Cadillac Engine Discussion; Hi , I have a 96 fleetwood that has a pass key fault. The 'pass key fault' light comes on ...
    mutaal is offline Cadillac Owners Member
    Oct 2012
    3
    Hi , I have a 96 fleetwood that has a pass key fault. The 'pass key fault' light comes on and the engine won't crank , then after some time the light goes off on its own and the engine cranks and runs! At times the light comes on while the car is running but it doesn't affect anything.
    I've tried using the other key and remote but no luck... Help me plz!!!!
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,464
    Re: 96 fleetwood pass key fault
    It's usually caused by a broken wire for the ignition cylinder. Do a search for pass key, there are posts that say how to bypass it and also diagnose it.
    Feb 2003
    california
    69
    6,680
    google "by pass VATS" its a matter of wiring in a resistor
    Oct 2012
    3
    I've already changed the switch and got new keys but it made no difference!
    I've tried by-passing with a resistor but still no luck!
  7. Remove Advertisements
