Need help ..
Results 1 to 5 of 5
5.0 and 5.7 Discussion, Need help .. in Cadillac Engine Discussion; I have started conversion from 350 5.7 to 350 i ttook out of 74 impala... I have three issues... #1 ...
    Georgiaboi is offline Cadillac Owners Member
    Sep 2004
    4
    Need help ..
    #1 the tranny will the cadillac tranny hold up...
    #2 fuel pump issues if i keep caddy pump...(regulator or electric Pump)
    #3 I keep hearing issues with tranny and other things with computer... do . I need computer if i'm using totally carb motor no intake conversion...
    Last one what othe rissues do i need to consider...
    FASSTWOOD's Avatar
    FASSTWOOD is offline Cadillac Owners Enthusiast
    Automobile(s): 1995 Fleetwood Brougham
    Aug 2003
    Queens, NY
    44
    709
    Re: Need help ..
    What kind of caddy are you putting it in. I dont think the trany will work. use the tranny from the 74. You wont need the computer.
    Sep 2004
    4
    Re: Need help ..
    1991 brougham
    barge master's Avatar
    barge master is offline Cadillac Owners Enthusiast
    Northern Ct.
    53
    624
    Re: Need help ..
    I dunno Fasstwood, the tranny ought to bolt right up, but the older engines flexplate will be larger. I'm not sure if it clears the bellhousing. He will need an early 80s flexplate,[small dia. 2pc. rear main]. I'd try to keep the original tranny. Swapping that will be another set of problems that will be worse than the engine.
    Another thing worth noting, I put a pre-77 [large frame] 350 into an 84 Caprice and found the brackets on the engine were wider. They didn't look too much different at a glance, but they wouldn't land on the pads on the frame. I had to jack it back out, and pull the brackets off the 305 I'd taken out.
    You don't want to try and run that carb on the TBI fuel pump, too much pressure. You're probably gonna need to get a regular sending unit from an older car for your gas tank and get that pump out of there. You're retrofitting that baby to the 1970s. Even with the ease of Chevy interchange you're gonna get some surprises.
    evilrussian's Avatar
    evilrussian is offline Cadillac Owners Enthusiast
    Automobile(s): '83 SDV, '91 SDV
    Nov 2003
    Pembroke Pines, FL
    38
    531
    Re: Need help ..
    What tranny do you have? I've got a 2004r which has a BOP bolt pattern and bolts up to just about any GM v8 or v6 engine of that era. Mine was connected to the HT4100 which I swapped for '91 350 later. I had to toss the TBI and go with the Q-Jet carb which is fed by original electric pump, it's only 10 psi if I'm not mistaken. You'd have to check how much pressure does your TBI have though...
  8. Remove Advertisements
