Results 1 to 3 of 3
Thread: Wiring harness
    Eldorado guy is offline Cadillac Owners Fanatic
    Automobile(s): '80 Eldorado, '50 Chrysler Windsor, '92 Ford F-250 7.3 4x4
    Jun 2006
    26
    112
    Wiring harness
    Just a quick question. Is the wiring harness for the 1975-1980 Seville with the 5.7L engine the same as the 1979-1980 Eldorados with the 5.7? My Eldorado went through a fire a while back and it destroyed lots of the various connectors. I replaced most of them, but it still runs rough at idle and cuts out on take off (especially when cold, but still does it some when it's hot). Some of the connectors are still bad and one of the firewall connection "clusters" are really melted. Does anyone know if the harnesses are the same? The junkyard has two Sevilles right now...
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,476
    Re: Wiring harness
    The part on the engine might be similar but the rest is probably different. They're 2 completely different cars.
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    Re: Wiring harness
    The harness is just wiring. I would go to the yard and scavenge as many connectors as I could, before the cars get crushed. This way you have all the pieces, and then you just need to splice them into the circuit and build you own harness.
  • You may not post replies
