Does anyone know if there is a Throttle body fuel injection to Multiport fuel injection conversion kit that would work on a 1993 fleetwood (V8 5.7 liter engine)? Or is my only option swapping out for a 5.7 liter chevy small block and utilizing an edelbrok conversion kit?
you may want to look into the accell kit. not sure if it will come with an intake manifold though. but hell, a multi-port manifold for a 350 should be easy enough to find. one thing though, the kit wont come cheap, around 2000 dinero i beleive.
I have a 1993 Fleetwood with the 5.7 liter v8 engine. The car has throttle body fuel injection and puts out around 185 hp and torque is 300@2400 rpm. Would like to convert to Multi-point fuel injection system. Edelbrock has a TBI to MPFI conversion kit for the chevy/gmc 5.7 liter engine. Now i have been told that the 1993 cadillac engine is just a stock chevy 5.7 liter engine. Is that true?
Also will i have problems with the computer chip when doing this conversion. Has anyone else done this or found another solution?
WWW.Jegs.com. SHould be under truck mods i believe. MPFI with manifold goes for i believe 1500-2000 bucks. Yes it will fit, i have the same basic motor in my truck. 1994 Chevy K5 blazer sport.
done a bit more research and yup it should fit on the engine....i guess i have only two worries now....will it fit under the hood(i believe kit raises airfilter 1.5 inches off stock. And more important will the chip from edelbrock work with the cadillac stock computer. When i spoke with the edelbrock tech person he stated the chip was not for a cadillac.......but its the same exact engine as the chevy/gmc trucks.....what gives?
Cadillac may have their own spin on the computer so it may be different. What to do is, cut a block of styrofoam 1.75 inches high and place it on the top of the air filter and see if you can shut the hood.
