Olds 307 Trouble
Results 1 to 3 of 3
5.0 and 5.7 Discussion, Olds 307 Trouble in Cadillac Engine Discussion; I bought an 84 Delta 88 with a 307 a few months ago so I could give my Caddy a ...
    MaineWater's Avatar
    MaineWater is offline Cadillac Owners Fanatic
    Automobile(s): 1984 Coupe Deville, 1991 Brougham d'elegance, 1996 Deville
    Mar 2007
    Tewksbury,MA
    27
    219
    Olds 307 Trouble
    I bought an 84 Delta 88 with a 307 a few months ago so I could give my Caddy a break and was wondering if anyone could point me in a direction. It was fine until a long trip. First when it is cold it will conk when I put it in reverse after start up. Secondly If I push hard it will make a huge popping sound,ithas to be from the carb. The engine seems to run fine in idle butunder pressure it seems to struggle. All vaccuum lines seem fine except the top one in back, but that one seems like it has no effect when removed. Any ideas?
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: Olds 307 Trouble
    Popping through the carb could be a bad cam or burnt/bent valve. The only 307 I ever had burned a valve. A compression test and vacuum test will verify and/or rule out those obvious things. Those transmissions aren't exactly bulletproof either. Do you suppose that car had a few hot driving before it was sold?
    generaltso64's Avatar
    generaltso64 is offline Cadillac Owners Member
    Automobile(s): 88 brougham
    Jun 2010
    Tampa
    34
    12
    timing? bad plug wires?
