I need ideas on how to replace or repair my Window Washer Pump - for my '86 Fleetwood
Results 1 to 3 of 3
5.0 and 5.7 Discussion, I need ideas on how to replace or repair my Window Washer Pump - for my '86 Fleetwood in Cadillac Engine Discussion; I need ideas on how to replace or repair my Window Washer Pump - for my '86 Fleetwood Brougham. Part ...
    visitor200's Avatar
    visitor200 is offline Cadillac Owners Member
    Automobile(s): 1986 Fleetwood Brougham
    May 2010
    11
    QuestionI need ideas on how to replace or repair my Window Washer Pump - for my '86 Fleetwood
    Part is no longer available in dealer network. I push the dashboard button on the left signal arm, starts the wipers, but the pump is not pumping the water through the hose from the water storage unit.
    This is a 5" plastic pump that snaps into the top hole of the plastic water holding tank under the hood. I noticed some corrosion on the electrical tabs of the pump. (You think they can be cleaned?)
    NAPA auto parts is showing a different pump for the year, and their pump has 3 electrical tabs (the 3rd one I suspect is a ground), which mine only has two electrical tabs for the wiring harness to plug into.
    This is all new to me, trying to keep a 1986 Fleetwood Brougham (which I bought new in 1986 from Martin Cadillac) in decent running shape. Now I am faced with potentially more parts going bad and no place to find them.
    Thanks for all your help, and patience.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: I need ideas on how to replace or repair my Window Washer Pump - for my '86 Fleet
    I don't mess with those too much but I didn't think there were too many different versions of those pumps. They usually look about the same to me. I'm surprised NAPA didn't have one that would work. Maybe a bum NAPA, I would check another store to be sure.
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    Try an AC DELCO distributor. The part number is 22071780. Advance Auto parts is an AC DELCO distributor, but they don't have everything. Search Google Maps for certified distributors in your area.
