how can i lift my motor...just a little?
Results 1 to 2 of 2
5.0 and 5.7 Discussion, how can i lift my motor...just a little? in Cadillac Engine Discussion; I have a '86 fleetwood brougham i took the 307 olds and 200 tranny out of it and i am ...
    86FLEETWOOD is offline Cadillac Owners Member
    Automobile(s): 1986 CADILLAC FLEETWOOD BROGHAM
    Aug 2009
    34
    9
    I have a '86 fleetwood brougham i took the 307 olds and 200 tranny out of it and i am replacing it with a chevy 350 and 700r tranny. My problem is the motor is sitting too low causing my fuel pump to sit on my frame. I've tried to use the mounts from my car and the donors car as well but it will not fit. i am so close to having this finished i just need to raise my engine....just a little.
    SSG
    SSG is offline Cadillac Owners Member
    Automobile(s): NONE
    Nov 2009
    26
    Re: how can i lift my motor...just a little?
    You may want to get motor mounts for late '80's or early '90's. Caddy changed over to the chevy 305 or 350 around that time. Good Luck.
    Steve
