89 Brougham gas smell...
Results 1 to 5 of 5
5.0 and 5.7 Discussion, 89 Brougham gas smell... in Cadillac Engine Discussion; Hey fellas, I'm in need of some help. My 89 Brougham, 5.0 v8 (Olds 307) is having some issues. After ...
    AElayyat's Avatar
    AElayyat is offline Cadillac Owners Connoisseur
    Automobile(s): 85 Fleetwood Brougham, 90 Brougham 5.7, 05 Deville DTS
    Feb 2004
    So. Cali
    35
    1,135
    After driving the car for about 10 min & I park the car, come back to it, fire it back up I am smelling gas. I also noticed that as I am driving I smell gas. I have not drove the vehicle since this problem poped up yesterday. I think the gas smell after being driven had been around for a little while, but I only drive the car on week-ends.
    Any suggestions on what the issue may be. I have not got a chance to take the air cleaner off & look around, but any specific issues/known problems I should look for?
    Thanks in advance guys.
    VortecCaddy is offline Cadillac Owners Member
    Automobile(s): 1990 Cadillac Fleetwood Brougham
    Sep 2008
    BALTIMORE, MD
    34
    80
    Re: 89 Brougham gas smell...
    Start with the basics. Check injector pod first. Check gas lines and gas tank. Also take a look at the charcoal canister. Could be gas fumes escaping from there.
    Slacker is offline Cadillac Owners Fanatic
    Automobile(s): 1987 Cadillac Fleetwood Brougham
    Jun 2008
    125
    Agreed with above. Check if it's a gas vapor vent leak or a gas leak. My 307 just started to have the same issue. It ends up my carb is leaking. I'm waiting for a rebuild kit to come in so I can rebuild it.
    AElayyat's Avatar
    Feb 2004
    So. Cali
    35
    1,135
    OK guys, I will start with the simple stuff first & I'll report back. Thanks for the tips.
    Feb 2003
    california
    69
    6,679
    Very common to have a small leak where the fuel inlet pipe attaches to the carb. Run your finger under the fitting on the carb, most likely it will be damp with fuel. Requires 2 wrenches to loosen then retighten. When the small inlet fuel filter's been replaced most people use the wrong wrench and leave the larger inlet nut looose or they tear the thin gasket behind the larger nut.
  8. Remove Advertisements
