Rare find, 307 Olds rebuilt ready to go
Results 1 to 5 of 5
5.0 and 5.7 Discussion, Rare find, 307 Olds rebuilt ready to go in Cadillac Engine Discussion; Sorry moderators, no other way to list this to help out members, it isn't mine, just a good find for ...
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,533
    Sorry moderators, no other way to list this to help out members, it isn't mine, just a good find for someone with a need for a 307.
    http://www.racingjunk.com/post/13615...am-Engine.html
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: Rare find, 307 Olds rebuilt ready to go
    It's probably a good deal if someone needs one. I've got a thing about loose piston clearance and power honing the block and putting the stock pistons back in raises some questions for me. It might be perfectly fine and I'm sure it will run good enough but I wonder how many thousandths they honed out of the cylinders. The name of the website might put things in perspective. You don't get much for $800 nowadays so it is still a good deal if you need one.
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    50
    7,533
    Yup, rebuilding one yourself would cost 2x that, might as well then start with a 350 Olds and some good heads and make 2x the power of the 307 with not much diff in mpg. Loose pistons in bore aren't cool, ask GM, piston slap.....
    Quote Originally Posted by cadillac_al View Post
    Scraped Knuckles is offline Cadillac Owners Member
    Automobile(s): 81 Eldo
    Jan 2009
    13
    The 307 isn't worth it. There's a couple of engine rebuilding companies near me that only charge $1050 $1200 for hydraulic cam V8's and $1400 $1500 for roller cam V8's (Ford, GM excluding Cadillac, Dodge). There's a big differnce from a re-ring and bearing job to a complete rebuild. It could be worth $400-$600 if they could prove it runs and has good oil pressure. The V8's have weak oiling systems and will have bottom end failure with low oil pressure (which is probably why they put new rings and bearings in a low mileage engine).
    Slacker is offline Cadillac Owners Fanatic
    Automobile(s): 1987 Cadillac Fleetwood Brougham
    Jun 2008
    125
    Quote Originally Posted by Scraped Knuckles View Post
    Agreed. I payed around $200 for my 307 with transmission and pretty much complete. (Just missing carb, dist, and accessories). It currently has ~50k miles on both...
  8. Remove Advertisements
