Trouble Starting...
Results 1 to 4 of 4
5.0 and 5.7 Discussion, Trouble Starting... in Cadillac Engine Discussion; I have a 2000 Escalade with 169,000 miles on it. Runs great until it rains. Then I have problems with ...
    8yroldLacTrk is offline Cadillac Owners Member
    Automobile(s): Escalade
    Jul 2008
    Orlando FL
    9
    Trouble Starting...
    I have a 2000 Escalade with 169,000 miles on it. Runs great until it rains. Then I have problems with it starting. It turns over, starts but dies. After letting it sit for 2-3 hours, it starts right up and I have no problems with it for a while. This doesn't happen everytime it rains, but that's one common factor. I've had the fuel pump and assembly replaced, recent tune up. What could be causing this.
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    49
    7,531
    Re: Trouble Starting...
    Any trouble codes? First step is to find them.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Running bad in the rain is the classic symptom of failing spark plug wires. I don't know if the 2000 Escalade even has plug wires anymore. Checking for codes should still be the first step though.
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    49
    7,531
    Any codes?
    It has them, but they are short. The trucks have the (supposedly) more robust coils.
    I would look at the CTS/IAT. With a datalogger, when cold, they should match within a couple degrees of each other.
    You can take the connectors of each and put in a resistor of the same value in each, one that matches room temp (there is a chart I know I have posted before, can be found easily on the net) and see if that clears it up.
  7. Remove Advertisements
